If the host name of the printer is registered in the DNS server, you can enter ["host name"."domain name"] instead of the IP address.
Input Example: http://my_printer.xy_dept.company.com/
If you want to use SSL encrypted communication, enter "https://<the IP address or name of the printer>/". If the [Security Alert] dialog box or other dialog box appears, follow the directions in the message.
Input Example: https://192.168.0.215/
If the Remote UI top page is not displayed
(1)
Select [Management Mode].
(2)
Enter the password in [Password].
(3)
Click [Log In].
(1)
Select [End-User Mode].
(2)
Enter [User Name] as needed.
(3)
Click [Log In].
About [User Name]
If you want to log in by entering [User Name], permit job operations by end-users in [Management Settings] in the [Settings/Registration] - [Management Settings] - [Security] page.
Although it is possible to log in without entering any value for [User Name], logging in by entering the user name enables to operate the jobs for which the user names correspond with each other.
If you click [Log In] with only spaces entered into [User Name], an error message appears.
The value to be entered for [User Name] is the user name you entered when logging in to the computer.
About department ID management
When the department ID management function is enabled, you can log in by entering the department ID and password.
About SSO-H
When SSO-H is enabled, you can log in by entering the user name and password specified for SSO-H, and log in destination.
