Initializing the [Setup] Menu Using the Printer's Control Panel
Initialization of the [Setup] menu resets the settings specified in the common [Setup] menu and exclusive [Setup] menu to the default settings.
Initialize the settings by selecting [Initialize Menu] in the hierarchy of "Options" in the [Setup] menu. Start the key operation from Step 1.
Setting items which are not initialized
The following setting items are not initialized.
[Network] Options
[Adj. Start Position] ([User Maintenance] Options)
If <Initialize failed.> is displayed
If the message <Initialize failed.> appears when the initialization of the [Setup] menu is executed, the [Setup] menu is not initialized.
Make sure that the Job indicator is off, and then perform [Initialize Menu] again.
Do not turn the printer OFF during the initialization.
The printer memory may be damaged.
About some setting items
Some setting items do not become effective unless you cycle the power of the printer or perform a hard reset after initializing the [Setup] menu.
Canceling the initialization
If you press [  ] (Online) during the operation, the operation is canceled. However, you cannot cancel the operation when <Initializing...> is displayed even if you press [  ] (Online).
1
Press [  ] (Settings).
2
Select [Initialize Menu] using [  ] or [  ], and then press [OK].
3
Select [Yes] using [  ], and then press [OK].
While the initialization is being performed, <Initializing...> is displayed.
<Init. complete.> is displayed after the initialization is completed.
» Managing the Printer » Initializing the Settings » Initializing the [Setup] Menu Using the Printer's Control Panel
08X4-0C5
