e-ManualTopSite mapHelp
Category Top
Flow of Operations on the Settings/Registration Screen
Flow of Operations for Administrators
Flow of Operations for General Users
Settings/Registration Table
Preferences
Adjustment/Maintenance
Function Settings
Function Settings: Printer
Function Settings: Store/Access Files
Function Settings: Secure Print
Function Settings: Web Access
Management Settings
Preferences
Paper Settings
Registering the Paper Size and Type for a Paper Source
Setting the Paper Size Group for Auto Recognition in the Paper Source
Distinguishing A5 and STMT Paper
Registering/Editing Custom Paper Types
Registering Multi-Purpose Tray Default Settings
Registering/Editing/Deleting Custom Paper Sizes
Display Settings
Default Screen after Startup/Restoration
Default Screen (Status Monitor/Cancel)
Store Location Display Settings
Enabling the Language/Keyboard Switch
Changing the Display Language/Keyboard on the Touch Panel Display
Changing the Keyboard Shift Lock Feature Settings
Displaying the Remaining Paper Message
Number of Copies/Wait Time Status Display
Setting the Default Display of the Paper Type Selection Screen
mm/Inch Entry Switch
Displaying the Current Department ID/User Name
Displaying the Remaining Toner Error Message
Deleting the Remaining Toner Error Message
Timer/Energy Settings
Current Time Adjustment
Current Date and Time
Time Format
Quick Startup Settings
Auto Reset Time
Default Display after Auto Reset
Auto Sleep Time
Energy Consumption in the Sleep Mode
Auto Sleep Weekly Timer Settings
Setting the Sleep Mode Exit Time
Accessibility
Key Repetition Settings
Inverting the Screen Colors
Adjust Image Quality
Adjusting Gradation and Density
Auto Correct Color Mismatch
Dither Pattern Settings
Reducing Toner Used When Color Printing
Correcting Irregularities in Shaded Areas
Function Settings
Common
Paper Feed Settings
Enabling Paper Drawer Auto Selection
Matching the Print Side for 1-Sided and 2-Sided Printing
Enabling Timeout for Suspended Jobs
Paper Output Settings
Alternating the Print Output (Offset Jobs)
Inserting a Job Separation Sheet between Print Jobs
Inserting a Job Separation Sheet between Copy Sets
Print Settings
Setting the Printing Priority
Outputting Reports with Two-Sided Printing
Registering/Editing/Deleting User-Defined Text for Page Numbers and Watermarks
Access Files
Common Settings
Specifying the Stored File Settings
Memory Media Settings
Top » Settings/Registration » Adjustment/Maintenance » Adjust Image Quality » Adjusting Gradation and Density
0UKW-052
You can recalibrate the machine when you notice irregularities in the color of the prints, such as when prints turn out to be different from the original in gradation, density, or color.
The following two types of gradation adjustments can be made:
Visual Adjustment
This is a quick and simple adjustment that is made to the gradation, density, and color settings of the machine.
Automatic Adjustment
Print the test page and compare it with the color chart. Enter the result into the machine and adjust the gradation, density, and color of images. Visual adjustment adjusts more precisely than automatic adjustment.
It is recommended that you select [Visually Adjust] when performing an automatic gradation adjustment. Perform automatic adjustment for a quick but less complete adjustment between regular visual adjustments.
The paper that can be used with [Visually Adjust] is Thin, Plain 1, Plain 2, Recycled 1, and Recycled 2.
Test pages are not counted as part of the print total page counts.
Visual Adjustment
Prepare the color chart.
The color chart is included with the machine.
Press  (Settings/Registration).
Press [Adjustment/Maintenance] → [Adjust Image Quality].
4.
Press [Adjust Gradation] → [Visually Adjust].
To initialize the settings and redo visual adjustment, such as when visual adjustment is not performed correctly, press [Use Initial Set. for Adj. Visual.] → [On].
5.
Select the paper source of the paper to adjust → press [OK].
6.
Press [Start Printing].
If paper appropriate for the test page is not loaded in any paper source, a message asking you to load the appropriate paper appears. Load the appropriate paper in a paper source.
The test page is output.
7.
Press [Enter Values].
8.
Fold back the test page along the dotted lines. Place the test page over the color chart, compare the colors, and enter the number of the color with the closest density into the machine.
When entering the value for 'H Density (High)' for Cyan:
Fold back the test page along the dotted line 'High', and place it over the color chart.
Search for the color in the color chart that corresponds most closely with the Cyan under 'High' on the test page.
Example: If you determine that the color for '5' on the color chart is closest to that on the test page:
Enter '5' in the 'H Density (High)' field for Cyan on the machine.
Enter the Magenta, Yellow, and Black values for 'H Density (High)' in the same way that you did for Cyan.
It can be helpful to make a note of the values you have selected on printed on the test page. After comparing and writing down the values for multiple colors, you can enter all these values at once.
Enter the values for 'M Density (Mid)' and 'L Density (Low)' of each color using the procedure used for 'H Density (High)'.
When comparing the colors for 'M Density (Mid)' and 'L Density (Low)', fold back the printed test page along the dotted lines for 'M Density (Mid)' and 'L Density (Low)', and place the test page over the color chart.
Once you have entered values in each field, press [OK].
9.
Finish adjustment.
To finish without confirming the adjustment results:
Press [End].
The adjusted values are saved.
To finish after confirming the adjustment results:
Press [Check & Finish].
Confirm the print results of the test page.
Compare the colors on the printed test page and the color chart. Make sure that each color on the test page matches the values (colors) listed below on the color chart.
High:
3
Mid:
8
Low:
13
Press [Adjustment/Maintenance] → [Adjust Image Quality] → [Adjust Gradation].
Press [Auto Adjust].
4.
Press [Start].
