e-ManualTopSite mapHelp
Category Top
Flow of Operations on the Settings/Registration Screen
Flow of Operations for Administrators
Flow of Operations for General Users
Settings/Registration Table
Preferences
Adjustment/Maintenance
Function Settings
Function Settings: Printer
Function Settings: Store/Access Files
Function Settings: Secure Print
Function Settings: Web Access
Management Settings
Preferences
Paper Settings
Registering the Paper Size and Type for a Paper Source
Setting the Paper Size Group for Auto Recognition in the Paper Source
Distinguishing A5 and STMT Paper
Registering/Editing Custom Paper Types
Registering Multi-Purpose Tray Default Settings
Registering/Editing/Deleting Custom Paper Sizes
Display Settings
Default Screen after Startup/Restoration
Default Screen (Status Monitor/Cancel)
Store Location Display Settings
Enabling the Language/Keyboard Switch
Changing the Display Language/Keyboard on the Touch Panel Display
Changing the Keyboard Shift Lock Feature Settings
Displaying the Remaining Paper Message
Number of Copies/Wait Time Status Display
Setting the Default Display of the Paper Type Selection Screen
mm/Inch Entry Switch
Displaying the Current Department ID/User Name
Displaying the Remaining Toner Error Message
Deleting the Remaining Toner Error Message
Timer/Energy Settings
Current Time Adjustment
Current Date and Time
Time Format
Quick Startup Settings
Auto Reset Time
Default Display after Auto Reset
Auto Sleep Time
Energy Consumption in the Sleep Mode
Auto Sleep Weekly Timer Settings
Setting the Sleep Mode Exit Time
Accessibility
Key Repetition Settings
Inverting the Screen Colors
Adjust Image Quality
Adjusting Gradation and Density
Auto Correct Color Mismatch
Dither Pattern Settings
Reducing Toner Used When Color Printing
Correcting Irregularities in Shaded Areas
Function Settings
Common
Paper Feed Settings
Enabling Paper Drawer Auto Selection
Matching the Print Side for 1-Sided and 2-Sided Printing
Enabling Timeout for Suspended Jobs
Paper Output Settings
Alternating the Print Output (Offset Jobs)
Inserting a Job Separation Sheet between Print Jobs
Inserting a Job Separation Sheet between Copy Sets
Print Settings
Setting the Printing Priority
Outputting Reports with Two-Sided Printing
Registering/Editing/Deleting User-Defined Text for Page Numbers and Watermarks
Access Files
Common Settings
Specifying the Stored File Settings
Memory Media Settings
Top » Settings/Registration » Settings/Registration Table » Function Settings
Function Settings
0UKW-036
This section describes the Common items for Function Settings.
For the table of each function, see the following:
Function Settings: Common
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[Paper Feed Settings]
[Paper Drawer Auto Selection On/Off]
Printer, Other
Yes
No
MP Tray: On, Off
Off
Yes
No
Other: On, Off
On
Yes
No
[Feed Method Switch]
MP Tray and Other: Speed Priority, Print Side Priority
Speed Priority
Yes
No
[Suspended Job Timeout]
On, Off
Off
Yes
Yes
0 to 999 mins
5 mins
Yes
Yes
[Paper Output Settings]
[Offset Jobs]*1
On, Off
On
Yes
Yes
[Job Separator Between Jobs]
On, Off
Off
Yes
Yes
Change (Select Paper Source)
Yes
Yes
[Job Separator Between Copies]
On, Off
Off
Yes
No
Copies (1 to 9999)
10
Yes
No
Yes
No
[Print Settings]
[Print Priority]
Printer: 1, 2, 3
2
Yes
Yes
Access Strd Files, Other: 1, 2, 3
3
Yes
Yes
[Output Report Default Settings]
2-Sided Printing: On, Off
Off
Yes
Yes
[Register Characters for Page No./Watermark]
Register, Edit, Delete
Yes
Yes
[Secure Watermark/Document Scan Lock]*1
[Forced Secure Watermark/Doc. Scan Lock]
Access Stored Files, Printer: Do Not Set, Frcd. Secure Watermark, Forced Doc. Scan Lock
Do Not Set
Yes
Yes*2
[Printer Driver Watermark/Doc. Scan Lock]
Do Not Set, Driver Secure Watermark, Driver Doc. Scan Lock
Do Not Set
Yes
Yes*2
[Adjust Background/Character Contrast]
Sample Print
No
No
Black, Cyan, Magenta
Black
No
No
Relative Contrast: (-7 to +7)
Black: 2
Cyan: 2
Magenta: 0
No
No
Standard Value Set.: (1 to 64)
Black: 8
Cyan: 16
Magenta: 16
No
No
Latent Area Density: (1 to 36)
Black: 6
Cyan: 9
Magenta: 9
No
No
Print Settings
Background Pattern: None, Arabesque, Fans, Polka Dots, Stars, Mesh, Clouds, Cherry Blossoms, Leaves
None
No
No
Print Settings
Size: 36.0 pt, 54.0 pt, 72.0 pt
54.0 pt
No
No
Print Settings
White Letters on Colored Background: On, Off
Off
No
No
Sample Print
No
No
Initialize
No
No
[Adjust TL Code]
Color: Magenta, Black
Black
No
Yes
Dot Size: 1 to 7
Black: 4
Magenta: 4
No
Yes
Dot Density: Standard, Rough
Standard
No
Yes
Initialize
No
No
[Document Scan Lock Operational Settings]*1
Use Document Scan Lock/Embedded Info: On, Off
On
No
Yes
Multiple Embedded Information Action: Continue Job, Cancel Job
Cancel Job
No
Yes
Rstrct. Func. Affct. Doc. Scan Lock: On, Off
Off
No
Yes
*1
Indicates items that appear only when the appropriate optional product is available for use.
*2
Indicates items with no serial number or ID/user name.
