e-ManualTopSite mapHelp
Category Top
Flow of Operations on the Settings/Registration Screen
Flow of Operations for Administrators
Flow of Operations for General Users
Settings/Registration Table
Preferences
Adjustment/Maintenance
Function Settings
Function Settings: Printer
Function Settings: Store/Access Files
Function Settings: Secure Print
Function Settings: Web Access
Management Settings
Preferences
Paper Settings
Registering the Paper Size and Type for a Paper Source
Setting the Paper Size Group for Auto Recognition in the Paper Source
Distinguishing A5 and STMT Paper
Registering/Editing Custom Paper Types
Registering Multi-Purpose Tray Default Settings
Registering/Editing/Deleting Custom Paper Sizes
Display Settings
Default Screen after Startup/Restoration
Default Screen (Status Monitor/Cancel)
Store Location Display Settings
Enabling the Language/Keyboard Switch
Changing the Display Language/Keyboard on the Touch Panel Display
Changing the Keyboard Shift Lock Feature Settings
Displaying the Remaining Paper Message
Number of Copies/Wait Time Status Display
Setting the Default Display of the Paper Type Selection Screen
mm/Inch Entry Switch
Displaying the Current Department ID/User Name
Displaying the Remaining Toner Error Message
Deleting the Remaining Toner Error Message
Timer/Energy Settings
Current Time Adjustment
Current Date and Time
Time Format
Quick Startup Settings
Auto Reset Time
Default Display after Auto Reset
Auto Sleep Time
Energy Consumption in the Sleep Mode
Auto Sleep Weekly Timer Settings
Setting the Sleep Mode Exit Time
Accessibility
Key Repetition Settings
Inverting the Screen Colors
Adjust Image Quality
Adjusting Gradation and Density
Auto Correct Color Mismatch
Dither Pattern Settings
Reducing Toner Used When Color Printing
Correcting Irregularities in Shaded Areas
Function Settings
Common
Paper Feed Settings
Enabling Paper Drawer Auto Selection
Matching the Print Side for 1-Sided and 2-Sided Printing
Enabling Timeout for Suspended Jobs
Paper Output Settings
Alternating the Print Output (Offset Jobs)
Inserting a Job Separation Sheet between Print Jobs
Inserting a Job Separation Sheet between Copy Sets
Print Settings
Setting the Printing Priority
Outputting Reports with Two-Sided Printing
Registering/Editing/Deleting User-Defined Text for Page Numbers and Watermarks
Access Files
Common Settings
Specifying the Stored File Settings
Memory Media Settings
Top » Settings/Registration » Settings/Registration Table » Adjustment/Maintenance
0UKW-035
Adjustment/Maintenance: Adjust Image Quality
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[Adjust Gradation]
Visually Adjust
No
No
Auto Adjust
No
No
Use Initial Set. for Adj. Visual.: On, Off
Off
No
No
[Auto Correct Color Mismatch]
Start
No
No
[Dither Pattern Settings]
Pattern 1, Pattern 2
Pattern 1
No
No
[Adjust Toner Volume Used for Color Printing]
Off, Level 1, Level 2
Off
No
No
[Fill Area Image Adjustment Mode]
Mode 1, Mode 2, Mode 3
Mode 3
No
No
Adjustment/Maintenance: Maintenance
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[Clean Inside Main Unit]
Start key
No
No
[Clean Pressure Roller for Fixing]
Start Printing, Start Cleaning key
No
No
[Initialize After Replacing Parts]
[Fixing Assembly]
Yes, No
No
No
