e-ManualTopSite mapHelp
Category Top
Flow of Operations on the Settings/Registration Screen
Flow of Operations for Administrators
Flow of Operations for General Users
Settings/Registration Table
Preferences
Adjustment/Maintenance
Function Settings
Function Settings: Printer
Function Settings: Store/Access Files
Function Settings: Secure Print
Function Settings: Web Access
Management Settings
Preferences
Paper Settings
Registering the Paper Size and Type for a Paper Source
Setting the Paper Size Group for Auto Recognition in the Paper Source
Distinguishing A5 and STMT Paper
Registering/Editing Custom Paper Types
Registering Multi-Purpose Tray Default Settings
Registering/Editing/Deleting Custom Paper Sizes
Display Settings
Default Screen after Startup/Restoration
Default Screen (Status Monitor/Cancel)
Store Location Display Settings
Enabling the Language/Keyboard Switch
Changing the Display Language/Keyboard on the Touch Panel Display
Changing the Keyboard Shift Lock Feature Settings
Displaying the Remaining Paper Message
Number of Copies/Wait Time Status Display
Setting the Default Display of the Paper Type Selection Screen
mm/Inch Entry Switch
Displaying the Current Department ID/User Name
Displaying the Remaining Toner Error Message
Deleting the Remaining Toner Error Message
Timer/Energy Settings
Current Time Adjustment
Current Date and Time
Time Format
Quick Startup Settings
Auto Reset Time
Default Display after Auto Reset
Auto Sleep Time
Energy Consumption in the Sleep Mode
Auto Sleep Weekly Timer Settings
Setting the Sleep Mode Exit Time
Accessibility
Key Repetition Settings
Inverting the Screen Colors
Adjust Image Quality
Adjusting Gradation and Density
Auto Correct Color Mismatch
Dither Pattern Settings
Reducing Toner Used When Color Printing
Correcting Irregularities in Shaded Areas
Function Settings
Common
Paper Feed Settings
Enabling Paper Drawer Auto Selection
Matching the Print Side for 1-Sided and 2-Sided Printing
Enabling Timeout for Suspended Jobs
Paper Output Settings
Alternating the Print Output (Offset Jobs)
Inserting a Job Separation Sheet between Print Jobs
Inserting a Job Separation Sheet between Copy Sets
Print Settings
Setting the Printing Priority
Outputting Reports with Two-Sided Printing
Registering/Editing/Deleting User-Defined Text for Page Numbers and Watermarks
Access Files
Common Settings
Specifying the Stored File Settings
Memory Media Settings
Top » Settings/Registration » Settings/Registration Table » Preferences
Preferences
0UKW-034
Preferences: Paper Settings
Item
Setting Description
Default
Setting
Can be set in
Remorte UI
Device Information
Delivery Available
[Paper Settings]
Paper Source
Set:
Thin(16 bond), Plain, Heavy 1(29 bond-34 bond), Heavy 2(35 bond-60 cover), Color(17 bond-20 bond), Recycled 1(17 bond-20 bond), Recycled 2(21 bond-24 bond), Recycled 3(25 bond-28 bond), Pre-Punched
Custom Size: S1 to S4
Envelope: No. 10 (COM10), DL, ISO-C5, Monarch, Nagagata 3, Yougatanaga 3
Plain
Yes
No
<Plain Paper Basis Weight Settings>: Plain 1(17 bond-20 bond), Plain 2(21 bond-24 bond), Plain 3(25 bond-28 bond)
Yes
No
[Paper Size Group for Auto Recog. in Drawer]
A/B Size, Inch Size
Inch Size
[A5/STMT Paper Selection]
A5, STMT
STMT
No
No
[Paper Type Management Settings]
Details/Edit
Name, Category, Basis Weight, Finish, Type, Color
Yes
No
Duplicate, Delete
Yes
No
[Register Multi-Purpose Tray Defaults]
On, Off
Register(Paper Size/Paper Type)
Off
No
No
[Register Custom Size]
S1 to S4:
Register/Edit, Rename
No
Yes
Delete
No
No
Preferences: Display Settings
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[Default Screen after Startup/Restoration]
Main Menu, Quick Menu, Access Stored Files, Secure Print, Web Access*1
Main Menu
No
No
Open Status Monitor/Cancel: On, Off
On
No
No
[Default Screen (Status Monitor/Cancel)]
Default Status Type: Print, Consumables
Print
No
No
Status/Log: Job Status, Log
Job Status
No
No
Details (Print, Log): Printer, Local Print, Print Report
No
No
[Store Location Display Settings]
Network: On, Off
On
No
No
Memory Media: On, Off
Off
No
No
[Language/Keyboard Switch On/Off]
On, Off
Off
No
No
[Language/Keyboard Switch]
Language, Keyboard Layout
No
No
[Use Keyboard Shift Lock Feature]
On, Off
Off
No
Yes
[Display Remaining Paper Message]
On, Off
On
No
No
[No. of Copies/Job Duration Status]
On, Off
On
No
No
[Paper Type Selection Screen Priority]
Simple, Detailed
Simple
No
No
[mm/Inch Entry Switch]
mm, Inch
Inch
No
Yes
[ID/User Name Display On/Off]
On, Off
On
No
No
[Display Remaining Toner Error Message]
On, Off
Off
No
No
*1
Indicates items that appear only when the appropriate optional product is available for use.
Preferences: Timer/Energy Settings
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[Adjust Time]
00:00 to 23:59, in one minute increments
No
No
[Date/Time Settings]
Date and Time Setting (12 digit number)
Yes
No
Time Zone: GMT-12:00 to GMT+12:00
GMT-05:00
Yes
No
Daylight Saving Time: On, Off
Off
Yes
No
Start Date (Month/Day/Time (0 to 23))
April, 1st, Sunday, 2:00
Yes
No
End Date (Month/Day/Time (0 to 23))
October, Final, Sunday, 2:00
Yes
No
[Time Format]
24 Hour, 12 Hour
12 Hour
Yes
No
[Quick Startup Settings for Main Power]
On, Off
On
Yes
Yes
Startup Speed Priority: On, Off
On
Yes
No
[Auto Reset Time]
0 min=Off, 10 to 50 seconds in 10 second increments, 1 to 9 minutes in one minute increments
2 mins
Yes
Yes
[Restrict Auto Reset Time]
On, Off
Off
Yes
Yes
[Function After Auto Reset]
Initial Function, Selected Function
Initial Function
Yes
Yes
[Auto Sleep Time]
10 seconds, 1, 2, 10, 15, 20, 30, 40, 50 mins, 1 hr, 90 mins, 2, 3, 4 hrs
1 min*1
Yes
Yes
[Sleep Mode Energy Use]
Low, High
Low
Yes
Yes
[Auto Sleep Weekly Timer]
Sun to Sat, 00:00 to 23:59, in one minute increments
Yes
Yes
[Sleep Mode Exit Time Settings]
Yes
Yes
*1
It is recommended that you use the default setting for this item.
Preferences: Network
If you are configuring the settings for the first time in "Interface Settings," "TCP/IPv4 Settings," "TCP/IPv6 Settings," or "Settings Common to TCP/IPv4 and TCP/IPv6," use the control panel of the machine. After configuring the TCP/IP settings, you can change them using the Remote UI.
If you are using a NetWare network, you must use the TCP/IP protocol if you want to specify settings using software other than the control panel of the machine.
Output Report(See "Confirming Settings.")
Item
Setting Description
Default Setting
Can be set in Remote UI
Device Information Delivery Available
[Output Report]
Yes, No
Yes
No
Confirm Network Connection Set. Changes(See "Interface Settings.")
Item
Setting Description
Default Setting
[Confirm Network Connection Set. Changes]
On, Off
Off
No
Yes
TCP/IP Settings: IPv4 Settings(See "TCP/IPv4 Settings.")
Item
Setting Description
Default Setting
Can be set in
Remote UI
Device Information
Delivery Available
[IPv4 Settings]
[Use IPv4]
On, Off
On
Yes
No
[IP Address Settings]
IP Address
0.0.0.0
Yes
No
Subnet Mask
0.0.0.0
Yes
No
Gateway Address
0.0.0.0
Yes
No
DHCP: On, Off
Off
Yes
Yes
Auto IP: On, Off
Off
Yes
No
[DHCP Option Settings]
Acquire Host Name: On, Off
On
Yes
No
DNS Dynamic Update: On, Off
Off
Yes
No
[PING Command]
IPv4 Address
0.0.0.0
No
No
TCP/IP Settings: IPv6 Settings(See "TCP/IPv6 Settings.")
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[IPv6 Settings]
[Use IPv6]
On, Off
Off
Yes
No
[Stateless Address Settings]
Use Stateless Address: On, Off
On
Yes
No
[Manual Address Settings]
Use Manual Address: On, Off
Off
Yes
No
Manual Address (IPv6 Address (39 characters maximum))
Yes
No
Prefix Length: 0 to 128
64
Yes
No
Default Router Addr. (39 characters maximum)
Yes
No
[Use DHCPv6]
On, Off
Off
Yes
Yes
[PING Command]
No
No
Host Name
No
No
TCP/IP Settings: DNS Settings(See "TCP/IPv4 Settings.")
Item
Setting Description
Default Setting
Can be set in
Remote UI
Device Information
Delivery Available
[DNS Settings]
[DNS Server Address Settings]
Primary DNS Server (IPv4 Address)
0.0.0.0
Yes
No
Secondary DNS Server (IPv4 Address)
0.0.0.0
Yes
No
[DNS Host/Domain Name Settings]
Host Name
Canon****** ("******" represents the last six digits of a MAC address.)
Yes
No
Domain Name
(NULL)
Yes
No
[DNS Dynamic Update Settings]
Off
Yes
No
[mDNS Settings]
Use IPv4 mDNS: On, Off
Off
Yes
No
mDNS Name (63 characters maximum)
(NULL)
Yes
No
TCP/IP Settings: DNS Settings(See "TCP/IPv6 Settings.")
Item
Setting Description
Default Setting
Can be set in
Remote UI
Device Information
Delivery Available
[DNS Settings]
Primary DNS Server (IPv6 Address)
Yes
No
Secondary DNS Server (IPv6 Address)
Yes
No
Use Same Host Name/Domain Name as IPv4: On, Off
Off
Yes
No
Host Name
Yes
No
Domain Name
Yes
No
Off
Yes
No
Register Stateless Address: On, Off
Off
Yes
No
Register Manual Address: On, Off
Off
Yes
No
Register Stateful Address: On, Off
Off
Yes
No
[mDNS Settings]
Use IPv6 mDNS: On, Off
Off
Yes
No
Use Same mDNS Name as IPv4 mDNS: On, Off
Off
Yes
No
(NULL)
Yes
No
TCP/IP Settings
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[WINS Settings]
WINS Resolution: On, Off
Off
Yes
No
WINS Server Address (IP Address)
0.0.0.0
Yes
No
Node Type: Auto (display only)
No
No
Scope ID
(NULL)
Yes
No
[LPD Print Settings]
On, Off
On
Yes
Yes
LPD Banner Page*1: On, Off
Off
Yes
Yes
[RAW Print Settings]
On, Off
On
Yes
Yes
Bidirectional Communication: On, Off
Off
Yes
Yes
[SNTP Settings]
Use SNTP: On, Off
Off
Yes
No
Polling Interval: 1 to 48 hrs, in one hour increments
24
Yes
No
NTP Server Address (IP Address or Host Name)
(NULL)
Yes
No
Check NTP Server
Yes
No
[FTP Print Settings]
Use FTP Printing: On, Off
Off
Yes
Yes
User Name
guest
Yes
No
Password
7654321
Yes
No
[WSD Settings]
Use WSD: On, Off
Off
Yes
Yes
Use WSD Browsing: On, Off
Off
Yes
Yes
[IPP Print Settings]
On, Off
Off
Yes
Yes
Use SSL: On, Off
Off
Yes
No
Use Authentication: On, Off
Off
Yes
No
User Name
guest
Yes
No
Password
7654321
Yes
No
[Multicast Discovery Settings]
Response: On, Off
On
Yes
Yes
Scope Name
default
Yes
No
[Use HTTP]
On, Off
On
Yes
Yes
[SSL Settings]
Settings that use SSL
Yes
No
[Key and Certificate]
Set as the Default Key
Yes
No
Certificate Details (Version, Serial Number, Signature Algorithm, Issue Destination, Validity Start Date, Validity End Date, Issuer, Public Key, Certificate Thumbprint, Verify Cert.)
Yes
No
Display Use Location (Displays what the key pair is being used for)
Yes
No
[Proxy Settings]
Use Proxy: On, Off
Off
Yes
No
Server Address (IP Address or FQDN)
(NULL)
Yes
No
Port Number: 1 to 65535
80
Yes
No
Use Proxy within the Same Domain: On, Off
Off
Yes
No
[Set Authentication]
Use Proxy Auth.: On, Off
Off
Yes
No
User Name
(NULL)
Yes
No
Password
(NULL)
Yes
No
[Confirm Dept. ID PIN]
On, Off
Off
Yes
No
*1
IPSec Settings(See "IPSec Settings.")
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[IPSec Settings]
<Use IPSec>
On, Off
Off
Yes
No
<Receive Non-Policy Packets>
Allow, Reject
Allow
Yes
No
[Policy On/Off]
On, Off
Off
Yes
No
[Reg.]
Policy Name (24 characters maximum)
(NULL)
Yes
No
[Selector Settings]
Local Address(All IP Addrs., IPv4 Address, IPv6 Address, IPv4 Manual Settings, IPv6 Manual Settings)
All IP Addrs.
Yes
No
IPv4 Manual Settings(Single Address, Address Range(First Address, Last Address), Subnet Settings(Address, Subnet Mask))
Single Address
Yes
No
IPv6 Manual Settings (Single Address(Address), Address Range (First Address, Last Address), Specify Prefix (Address, Prefix Length))
Single Address
Yes
No
Prefix Length (0 to 128)
64
Yes
No
Remote Address(All IP Addrs., All IPv4 Addrs., All IPv6 Addrs., IPv4 Manual Settings, IPv6 Manual Settings)
All IP Addrs.
Yes
No
Single Address
Yes
No
Single Address
Yes
No
64
Yes
No
Port (Specify by Port Number, Specify by Service Name)
Yes
No
Specify by Port Number(Local Port(All Ports, Single Port), Remote Port(All Ports, Single Port))
All Ports
Yes
No
Single Port (1 to 65535)
0
Yes
No
Service On/Off: On, Off
Off
Yes
No
[IKE Settings]
IKE Mode: Main, Aggressive
Main
Yes
No
Authentication Method: Pre-Shared Key Method (Shared Key), Digital Sig. Method (Key and Certificate)
Yes
No
Key and Certificate:
Yes
No
Certificate Details(Version, Serial Number, Signature Algorithm, Issue Destination, Validity Start Date, Validity End Date, Issuer, Public Key, Certificate Thumbprint, Verify Cert.)
Yes
No
Yes
No
Auth./Encryption Algorithm
(Auto, Manual Settings)
Auto
Yes
No
Auth./Encryption Algorithm: Manual Settings
Authentication
SHA1: On, Off
On
Yes
No
SHA2: On, Off
On
Yes
No
Encryption
3DES-CBC: On, Off
On
Yes
No
AES-CBC: On, Off
Off
Yes
No
DH Group:
Group1 (768), Group2 (1024), Group14 (2048), ECDH-P256, ECDH-P384
Group2 (1024)
Yes
No
[IPSec Network Settings]
Validity
Time: On, Off
On
Yes
No
On: (1 to 65535 mins)
480 mins
Yes
No
Validity
Off
Yes
No
On: (1 to 65535 MB)
0 MB
Yes
No
PFS: On, Off
Off
Yes
No
: Auto, Manual Settings
Auto
Yes
No
Auth./Encryption Algorithm: Manual Settings(ESP, ESP (AES-GCM), AH (SHA1))
ESP
Yes
No
ESP Settings:
ESP Auth.
SHA1: On, Off
On
Yes
No
NULL: On, Off
Off
Yes
No
ESP Encryption
3DES-CBC: On, Off
On
Yes
No
AES-CBC: On, Off
Off
Yes
No
NULL: On, Off
Off
Yes
No
ESP (AES-GCM) Settings: None
Yes
No
AH (SHA1) Settings: None
Yes
No
Connect. Mode:
Transport (display only)
No
No
[Edit]
Yes
No
[Delete]
Yes
No
[Print List]
Yes, No
No
No
NetWare Settings(See "Protocol Settings.")
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[NetWare Settings]
<Use NetWare>
On, Off
Off
Yes
Yes
<Frame Type>
Auto Detect, Ethernet II, Ethernet 802.2, Ethernet 802.3, Ethernet SNAP
Auto Detect
Yes
No
<IPX External Network Number>
Auto (display only)
No
No
<Node Number>
Auto (display only)
No
No
<Print Service>
Bindery PServer, RPrinter, NDS PServer, NPrinter
NDS PServer
Yes
No
<Packet Signature>
Auto (display only)
No
No
[Bindery PServer]
Print Server Name
(NULL)
Yes
No
File Server Name
(NULL)
Yes
No
Print Server Password
(NULL)
Yes
No
Printer Number: 0 to 15
0
Yes
No
Polling Interval: 1 to 15 sec
5 sec
Yes
No
Printer Form: 0 to 255
0
Yes
No
Buffer Size: 1 to 20 KB
20 KB
Yes
No
Service Mode: Minimize form changes within print queues, Minimize form changes across print queues, Change forms as needed, Service only currently mounted form
Yes
No
[RPrinter]
Print Server Name
(NULL)
Yes
No
File Server Name
(NULL)
Yes
No
0
Yes
No
[NDS PServer]
Print Server Name
(NULL)
Yes
No
Tree Name
(NULL)
Yes
No
Context Name
(NULL)
Yes
No
(NULL)
Yes
No
Printer Number: 0 to 254
0
Yes
No
Polling Interval: 1 to 255 sec
5 sec
Yes
No
0
Yes
No
Buffer Size: 3 to 20 KB
20 KB
Yes
No
Yes
No
[NPrinter]
Print Server Name
(NULL)
Yes
No
Tree Name
(NULL)
Yes
No
Context Name
(NULL)
Yes
No
0
Yes
No
SNMP Settings(See "Communication Environment Setup.")
Item
Setting Description
Default Setting
Can be set in
Remote UI
Device Information
Delivery Available
[SNMP Settings]
<Use SNMP v. 1>
On, Off
On
Yes
Yes
[Dedicated Comm. Settings]
Dedicated Community: On, Off
On
Yes
No
MIB Access Permission: Read/Write, Read Only
Read Only
Yes
No
[Set Community Name 1]
Community Name 1: On, Off
On
Yes
No
Read Only
Yes
No
Community Name
public
Yes
No
[Set Community Name 2]
Community Name 2: On, Off
Off
Yes
No
Read Only
Yes
No
Community Name
public2
Yes
No
<Use SNMP v. 3>
On, Off
Off
Yes
No
[User Settings]
User On/Off: On, Off
On
Yes
No
Reg. (User Name, MIB Access Permis. (Read/Write, Read Only), Security Settings (Auth. Yes/Encry. Yes, Auth. Yes/Encry. No, Auth. No/Encrypt. No), Authent. Algorithm (MD5, SHA1), Authent. Password, Encryption Algorithm (DES, AES), Encryption Password)
Yes
No
Details/Edit (User Name, MIB Access Permis. (Read/Write, Read Only), Security Settings (Auth. Yes/Encry. Yes, Auth. Yes/Encry. No, Auth. No/Encrypt. No), Authent. Algorithm (MD5, SHA1), Authent. Password, Encryption Algorithm (DES, AES), Encryption Password)
Yes
No
Delete
Yes
No
[Context Settings]
Register (Context name)
Yes
No
Edit (Context name)
Yes
No
Delete
Yes
No
<Get Printer Mgmt Info from Host>
On, Off
Off
Yes
Yes
[Reject SNMP Packets While in Sleep Mode]
On, Off
Off
Yes
No
Dedicated Port Settings(See "Communication Environment Setup.")
Item
Setting Description
Default Setting
[Dedicated Port Settings]
On, Off
On
Yes
Yes
Use Spool Function(See "Communication Environment Setup.")
Item
Setting Description
Default Setting
[Use Spool Function]
On, Off
Off
Yes
Yes
Startup Settings(See "Startup Time Settings.")
Item
Setting Description
Default Setting
[Startup Settings]
30 to 300 sec
30 sec
Yes
No
Ethernet Driver Settings(See "Interface Settings.")
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[Ethernet Driver Settings]
<Auto Detect>
On, Off
On
Yes
No
<Communication Mode>
Off: Half Duplex, Full Duplex
Half Duplex
Yes
No
<Ethernet Type>
Off: 10BASE-T, 100BASE-TX, 1000BASE-T
10BASE-T
Yes
No
<MAC Address>
Display only
No
No
IEEE 802.1X Settings(See "Selecting the IEEE802.1X Authentication Method.")
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[IEEE 802.1X Settings]
<Use IEEE 802.1X>
On, Off
Off
Yes
No
[Login Name]
Login Name
(NULL)
Yes
No
<Use TLS>
On, Off
Off
Yes
No
Yes
No
Yes
No
Display Use Location (Key and Certificate)
Yes
No
<Use TTLS>
On, Off
Off
Yes
No
<TTLS Settings (TTLS Protocol)>: MSCHAPv2, PAP
MSCHAPv2
Yes
No
<Use PEAP>
On, Off
Off
Yes
No
[User Name]
Name of the user to be authenticated with IEEE802.1X authentication
(NULL)
Yes
No
[Password]
Password of the user to be authenticated with IEEE802.1X authentication
(NULL)
Yes
No
[Same User Name as Login Name]
On, Off
On
Yes
No
Firewall Settings: IPv4 Address Filter(See "TCP/IPv4 Settings.")
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[IPv4 Address Filter]
[TX Filter]
Use Filter: On, Off
Off
Yes
No
Default Policy: Allow, Reject
Allow
Yes
No
Register (Up to 16 IPv4 addresses), Edit, Delete
Yes
No
Register
Single Address, Address Range (First Address, Last Address), Specify Prefix (Address, Prefix Length)
Edit
Single Address
Yes
No
Prefix Length (0 to 32)
Yes
No
[RX Filter]
Use Filter: On, Off
Off
Yes
No
Allow
Yes
No
Register (Up to 16 IPv4 addresses), Details/Edit, Delete
Yes
No
Register
Single Address, Address Range (First Address, Last Address), Specify Prefix (Address, Prefix Length), Port Number (Do Not Specify, Specify)
Specify (Port Number): Add, Delete
Single Address
Yes
No
Details/Edit
Yes
No
Yes
No
Firewall Settings: IPv6 Address Filter(See "TCP/IPv6 Settings.")
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[IPv6 Address Filter]
[TX Filter]
Use Filter: On, Off
Off
Yes
No
Allow
Yes
No
Register (Up to 16 IPv6 addresses), Edit, Delete
Yes
No
Register
Single Address (Address), Specify Prefix (IPv6 Prefix, Prefix Length)
Edit
Single Address
Yes
No
Yes
No
[RX Filter]
Use Filter: On, Off
Off
Yes
No
Allow
Yes
No
Register (Up to 16 IPv6 addresses), Details/Edit, Delete
Yes
No
Register
Single Address (Address), Specify Prefix (IPv6 Prefix, Prefix Length), Port Number (Do Not Specify, Specify)
Single Address
Yes
No
Details/Edit
Yes
No
Yes
No
Firewall Settings: MAC Address Filter(See "Settings Common to TCP/IPv4 and TCP/IPv6.")
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[MAC Address Filter]
[TX Filter]
Use Filter: On, Off
Off
Yes
No
Allow
Yes
No
Register (Up to 100 Mac addresses), Edit, Delete
Yes
No
[RX Filter]
Use Filter: On, Off
Off
Yes
No
Allow
Yes
No
Yes
No
Firewall Settings: IP Address Block Log(See "Checking the Block Log.")
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[IP Address Block Log]
Date, Type, IP Address, Port Number, Result, Details(Date, Type, IP Address, Port Number, Result)
Yes
No
Use AirPrint(See "AirPrint.")
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[Use AirPrint]
On, Off
Off
Yes
No
Device Position Information Settings(See "AirPrint.")
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[Device Position Information Settings]
Latitude, Longitude
Yes
No
Preferences: External Interface
USB Settings(See "Using the USB Port.")
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[USB Settings]
[Use as USB Device]
On, Off
On
Yes
Yes
[Use MEAP Driver for USB Input Device]
On, Off
Off
Yes
Yes
[Use MEAP Driver for External USB Device]
On, Off
Off
Yes
Yes
Preferences: Accessibility
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[Key Repetition Settings]
Standard, Slightly Slow, Slow
Standard
No
No
[Reversed Display (Color)]
On, Off
Off
No
No
Some items can be set using the Remote UI. Use the control panel of the device to set items which cannot be set using the Remote UI.
The names may be different on the Remote UI.
