e-ManualTopSite mapHelp
Category Top
Flow of Operations on the Settings/Registration Screen
Flow of Operations for Administrators
Flow of Operations for General Users
Settings/Registration Table
Preferences
Adjustment/Maintenance
Function Settings
Function Settings: Printer
Function Settings: Store/Access Files
Function Settings: Secure Print
Function Settings: Web Access
Management Settings
Preferences
Paper Settings
Registering the Paper Size and Type for a Paper Source
Setting the Paper Size Group for Auto Recognition in the Paper Source
Distinguishing A5 and STMT Paper
Registering/Editing Custom Paper Types
Registering Multi-Purpose Tray Default Settings
Registering/Editing/Deleting Custom Paper Sizes
Display Settings
Default Screen after Startup/Restoration
Default Screen (Status Monitor/Cancel)
Store Location Display Settings
Enabling the Language/Keyboard Switch
Changing the Display Language/Keyboard on the Touch Panel Display
Changing the Keyboard Shift Lock Feature Settings
Displaying the Remaining Paper Message
Number of Copies/Wait Time Status Display
Setting the Default Display of the Paper Type Selection Screen
mm/Inch Entry Switch
Displaying the Current Department ID/User Name
Displaying the Remaining Toner Error Message
Deleting the Remaining Toner Error Message
Timer/Energy Settings
Current Time Adjustment
Current Date and Time
Time Format
Quick Startup Settings
Auto Reset Time
Default Display after Auto Reset
Auto Sleep Time
Energy Consumption in the Sleep Mode
Auto Sleep Weekly Timer Settings
Setting the Sleep Mode Exit Time
Accessibility
Key Repetition Settings
Inverting the Screen Colors
Adjust Image Quality
Adjusting Gradation and Density
Auto Correct Color Mismatch
Dither Pattern Settings
Reducing Toner Used When Color Printing
Correcting Irregularities in Shaded Areas
Function Settings
Common
Paper Feed Settings
Enabling Paper Drawer Auto Selection
Matching the Print Side for 1-Sided and 2-Sided Printing
Enabling Timeout for Suspended Jobs
Paper Output Settings
Alternating the Print Output (Offset Jobs)
Inserting a Job Separation Sheet between Print Jobs
Inserting a Job Separation Sheet between Copy Sets
Print Settings
Setting the Printing Priority
Outputting Reports with Two-Sided Printing
Registering/Editing/Deleting User-Defined Text for Page Numbers and Watermarks
Access Files
Common Settings
Specifying the Stored File Settings
Memory Media Settings
Top » Settings/Registration » Function Settings » Common » Paper Feed Settings » Enabling Paper Drawer Auto Selection
0UKW-05A
Paper sources for which Paper Drawer Auto Selection is set to 'On' are used for Automatic Paper Selection and Auto Drawer Switching. You can set which paper sources can be used for Automatic Paper Selection and Auto Drawer Switching with each function.
Automatic Paper Selection (APS): The machine automatically selects the appropriate paper size (paper source) when you start printing.
Auto Drawer Switching (ADS): If the selected paper source runs out of paper during a print job, the machine automatically selects another paper source with the same paper size, and continues printing.
Automatic Paper Selection can only be used with LTR/LGL originals.
Auto Drawer Switching is not available for paper sources with [Print Side Priority] set for [Feed Method Switch].
Print (Printing from a Computer)
Paper sources with Paper Drawer Auto Selection set to 'On' and loaded with the following paper types, are eligible for use with Automatic Paper Selection and Auto Drawer Switching.
Auto Drawer Switching*3
If the paper type is specified*1
All paper types available on the machine are eligible for use with Automatic Paper Selection if they match the paper types specified on the printer driver.
If there is a paper source with the same paper size, type, and color, the machine automatically feeds from that paper source and continues printing.
If the paper type is not specified
Thin, Plain 1, Plain 2, Plain 3, Recycled 1, Recycled 2, Recycled 3, Color, or Custom*2
If there is a paper source with the same paper size and the paper type can be used with Automatic Paper Selection, the machine automatically feeds from that paper source and continues printing.
*1 Specify the type of paper in [Paper Type] on the printer driver.
*2 Paper equivalent to Thin, Plain 1, Plain 2, Plain 3, Recycled 1, Recycled 2, Recycled 3, or Color paper.
*3 If a specific paper source is set for [Paper Source] on the printer driver, Auto Drawer Switching is not performed.
Access Stored Files (the Advanced Box of Another Machine on the Same Network, Memory Media)
Automatic Paper Selection*1
*1 Depending on the paper size, such as custom size paper, the paper may not be eligible for use with Automatic Paper Selection.
*3 If a paper source is specified, Auto Drawer Switching is not performed.
Other (Printing Reports)
Paper sources with Paper Drawer Auto Selection set to 'On' and loaded with LGL or LTR size paper, are eligible for use with Automatic Paper Selection and Auto Drawer Switching. The available paper types are shown in the table below.
Thin, Plain 1, Plain 2, Plain 3, Recycled 1, Recycled 2, Recycled 3, or Custom*1
If there is a paper source with the same paper type and color, the machine automatically feeds from that paper source and continues printing.
*1 White Paper equivalent to Plain 1, Plain 2, Plain 3, Recycled 1, Recycled 2, or Recycled 3 paper.
Press [Function Settings] → [Common] → [Paper Feed Settings].
Press [Paper Drawer Auto Selection On/Off].
4.
Select the desired function → press [On] for each paper source → press [OK].
Press [Off] if you do not want to perform auto selection.
[Other] is used for specifying the paper source for printing reports.
Each button represents the following paper sources:
Staple Finisher-S1 and Cassette Feeding Unit-AH1 are attached.
At least one of the paper sources besides the multi-purpose tray must be set to 'On'.
5.
Press [OK].
