e-ManualTopSite mapHelp
Category Top
Flow of Operations on the Settings/Registration Screen
Flow of Operations for Administrators
Flow of Operations for General Users
Settings/Registration Table
Preferences
Adjustment/Maintenance
Function Settings
Function Settings: Printer
Function Settings: Store/Access Files
Function Settings: Secure Print
Function Settings: Web Access
Management Settings
Preferences
Paper Settings
Registering the Paper Size and Type for a Paper Source
Setting the Paper Size Group for Auto Recognition in the Paper Source
Distinguishing A5 and STMT Paper
Registering/Editing Custom Paper Types
Registering Multi-Purpose Tray Default Settings
Registering/Editing/Deleting Custom Paper Sizes
Display Settings
Default Screen after Startup/Restoration
Default Screen (Status Monitor/Cancel)
Store Location Display Settings
Enabling the Language/Keyboard Switch
Changing the Display Language/Keyboard on the Touch Panel Display
Changing the Keyboard Shift Lock Feature Settings
Displaying the Remaining Paper Message
Number of Copies/Wait Time Status Display
Setting the Default Display of the Paper Type Selection Screen
mm/Inch Entry Switch
Displaying the Current Department ID/User Name
Displaying the Remaining Toner Error Message
Deleting the Remaining Toner Error Message
Timer/Energy Settings
Current Time Adjustment
Current Date and Time
Time Format
Quick Startup Settings
Auto Reset Time
Default Display after Auto Reset
Auto Sleep Time
Energy Consumption in the Sleep Mode
Auto Sleep Weekly Timer Settings
Setting the Sleep Mode Exit Time
Accessibility
Key Repetition Settings
Inverting the Screen Colors
Adjust Image Quality
Adjusting Gradation and Density
Auto Correct Color Mismatch
Dither Pattern Settings
Reducing Toner Used When Color Printing
Correcting Irregularities in Shaded Areas
Function Settings
Common
Paper Feed Settings
Enabling Paper Drawer Auto Selection
Matching the Print Side for 1-Sided and 2-Sided Printing
Enabling Timeout for Suspended Jobs
Paper Output Settings
Alternating the Print Output (Offset Jobs)
Inserting a Job Separation Sheet between Print Jobs
Inserting a Job Separation Sheet between Copy Sets
Print Settings
Setting the Printing Priority
Outputting Reports with Two-Sided Printing
Registering/Editing/Deleting User-Defined Text for Page Numbers and Watermarks
Access Files
Common Settings
Specifying the Stored File Settings
Memory Media Settings
Top » Settings/Registration » Preferences » Display Settings » Number of Copies/Wait Time Status Display
0UKW-044
The number of copies specified and the approximate time before the current job completes are displayed on the bottom line of the touch panel display.
Press [Preferences] → [Display Settings] → [No. of Copies/Job Duration Status].
Press [On] → [OK].
Select [Off] if you do not want to display the approximate time before the current job completes.
The accuracy of the approximate times that appear on the bottom line of the touch panel display may vary, depending on the status of the machine.
The approximate time does not appear when the wait time is less than one minute.
