e-ManualTopSite mapHelp
Category Top
Flow of Operations on the Settings/Registration Screen
Flow of Operations for Administrators
Flow of Operations for General Users
Settings/Registration Table
Preferences
Adjustment/Maintenance
Function Settings
Function Settings: Printer
Function Settings: Store/Access Files
Function Settings: Secure Print
Function Settings: Web Access
Management Settings
Preferences
Paper Settings
Registering the Paper Size and Type for a Paper Source
Setting the Paper Size Group for Auto Recognition in the Paper Source
Distinguishing A5 and STMT Paper
Registering/Editing Custom Paper Types
Registering Multi-Purpose Tray Default Settings
Registering/Editing/Deleting Custom Paper Sizes
Display Settings
Default Screen after Startup/Restoration
Default Screen (Status Monitor/Cancel)
Store Location Display Settings
Enabling the Language/Keyboard Switch
Changing the Display Language/Keyboard on the Touch Panel Display
Changing the Keyboard Shift Lock Feature Settings
Displaying the Remaining Paper Message
Number of Copies/Wait Time Status Display
Setting the Default Display of the Paper Type Selection Screen
mm/Inch Entry Switch
Displaying the Current Department ID/User Name
Displaying the Remaining Toner Error Message
Deleting the Remaining Toner Error Message
Timer/Energy Settings
Current Time Adjustment
Current Date and Time
Time Format
Quick Startup Settings
Auto Reset Time
Default Display after Auto Reset
Auto Sleep Time
Energy Consumption in the Sleep Mode
Auto Sleep Weekly Timer Settings
Setting the Sleep Mode Exit Time
Accessibility
Key Repetition Settings
Inverting the Screen Colors
Adjust Image Quality
Adjusting Gradation and Density
Auto Correct Color Mismatch
Dither Pattern Settings
Reducing Toner Used When Color Printing
Correcting Irregularities in Shaded Areas
Function Settings
Common
Paper Feed Settings
Enabling Paper Drawer Auto Selection
Matching the Print Side for 1-Sided and 2-Sided Printing
Enabling Timeout for Suspended Jobs
Paper Output Settings
Alternating the Print Output (Offset Jobs)
Inserting a Job Separation Sheet between Print Jobs
Inserting a Job Separation Sheet between Copy Sets
Print Settings
Setting the Printing Priority
Outputting Reports with Two-Sided Printing
Registering/Editing/Deleting User-Defined Text for Page Numbers and Watermarks
Access Files
Common Settings
Specifying the Stored File Settings
Memory Media Settings
Top » Settings/Registration » Function Settings » Common » Paper Feed Settings » Matching the Print Side for 1-Sided and 2-Sided Printing
0UKW-05C
You can print on paper with printed logos while taking into account the print side (front/back) by using [Print Side Priority]. This mode enables you to print the first page of your original on the front side for both 1-sided and 2-sided prints without changing the orientation of the paper.
Printing Example
Paper with Printed Logos
Original
Front Side
Back Side
1-Sided Printing
2-Sided Printing
Prints each page on the front side.
Prints odd numbered pages (first, third, etc.) on the front side.
To achieve the above print results, load paper in the orientations indicated below.
Printing Method
Paper Source
Paper Load Orientation
When [Speed Priority] is set
1-Sided Printing
Paper Drawer
Front side facing up
Multi-Purpose Tray
Front side facing down
2-Sided Printing
Paper Drawer
Multi-Purpose Tray
When [Print Side Priority] is set
1-Sided/2-Sided Printing
Paper Drawer
Multi-Purpose Tray
Automatic Paper Selection and Auto Drawer Switching are not available for paper sources set to [Print Side Priority].
If [Print Side Priority] has been set for a paper source, the print speed for 1-Sided Printing will be reduced.
To print using the [Print Side Priority] settings, load the paper indicated below. For other paper, the message <Load paper.> appears and the paper is not fed, or the [Print Side Priority] settings are disabled.
Paper size: 5 1/2" x 8 1/4" (139.7 x 210 mm) to 8 1/2" x 14" (216 x 355.6 mm), LGL, LTR, EXEC, STMT, EXEC
Paper weight: 16 lb bond to 60 lb cover (60 to 163 g/m2)
Paper type: Thin, Plain 1, Plain 2, Plain 3, Color, Recycled 1, Recycled 2, Recycled 3, Pre-punched, Heavy 1, Heavy 2, or bond
Press [Function Settings] → [Common] → [Paper Feed Settings].
Press [Feed Method Switch].
4.
Press [Print Side Priority] for each paper source → [OK].
