e-ManualTopSite mapHelp
Category Top
Flow of Operations on the Settings/Registration Screen
Flow of Operations for Administrators
Flow of Operations for General Users
Settings/Registration Table
Preferences
Adjustment/Maintenance
Function Settings
Function Settings: Printer
Function Settings: Store/Access Files
Function Settings: Secure Print
Function Settings: Web Access
Management Settings
Preferences
Paper Settings
Registering the Paper Size and Type for a Paper Source
Setting the Paper Size Group for Auto Recognition in the Paper Source
Distinguishing A5 and STMT Paper
Registering/Editing Custom Paper Types
Registering Multi-Purpose Tray Default Settings
Registering/Editing/Deleting Custom Paper Sizes
Display Settings
Default Screen after Startup/Restoration
Default Screen (Status Monitor/Cancel)
Store Location Display Settings
Enabling the Language/Keyboard Switch
Changing the Display Language/Keyboard on the Touch Panel Display
Changing the Keyboard Shift Lock Feature Settings
Displaying the Remaining Paper Message
Number of Copies/Wait Time Status Display
Setting the Default Display of the Paper Type Selection Screen
mm/Inch Entry Switch
Displaying the Current Department ID/User Name
Displaying the Remaining Toner Error Message
Deleting the Remaining Toner Error Message
Timer/Energy Settings
Current Time Adjustment
Current Date and Time
Time Format
Quick Startup Settings
Auto Reset Time
Default Display after Auto Reset
Auto Sleep Time
Energy Consumption in the Sleep Mode
Auto Sleep Weekly Timer Settings
Setting the Sleep Mode Exit Time
Accessibility
Key Repetition Settings
Inverting the Screen Colors
Adjust Image Quality
Adjusting Gradation and Density
Auto Correct Color Mismatch
Dither Pattern Settings
Reducing Toner Used When Color Printing
Correcting Irregularities in Shaded Areas
Function Settings
Common
Paper Feed Settings
Enabling Paper Drawer Auto Selection
Matching the Print Side for 1-Sided and 2-Sided Printing
Enabling Timeout for Suspended Jobs
Paper Output Settings
Alternating the Print Output (Offset Jobs)
Inserting a Job Separation Sheet between Print Jobs
Inserting a Job Separation Sheet between Copy Sets
Print Settings
Setting the Printing Priority
Outputting Reports with Two-Sided Printing
Registering/Editing/Deleting User-Defined Text for Page Numbers and Watermarks
Access Files
Common Settings
Specifying the Stored File Settings
Memory Media Settings
Top » Settings/Registration » Preferences » Timer/Energy Settings » Energy Consumption in the Sleep Mode
0UKW-04R
You can set the amount of energy that the machine consumes when it is in the Sleep mode.
Press [Preferences] → [Timer/Energy Settings] → [Sleep Mode Energy Use].
Specify the following setting → press [OK].
Details of each item are shown below:
[Low]:
Energy consumption in the Sleep mode is low, but it takes longer to recover from the Sleep mode.
[High]:
Energy consumption in the Sleep mode is high, but it takes less time to recover from the Sleep mode.
If Sleep Mode Energy Use is set to 'Low', it may take more than 10 seconds for the touch panel to appear after pressing (Energy Saver).
If the machine is connected to a computer using a USB cable, depending on the timing for entering the sleep mode, the machine may be unable to receive data correctly. Reactivate the machine from the sleep mode, then execute the job again.
If the energy consumption level is set to 'Low', communication failure may occur, depending on the network utility software you are using. To avoid this, press (Energy Saver) to cancel the Sleep mode before using the machine.
The energy consumption level is 'High' even when set to 'Low', depending on the status and type of installed MEAP applications.
If you are using a management application to view or manage the settings and status of the machine via the network, the energy consumption level is 'High' even when set to 'Low'.
In the following cases, the energy consumption level in the Sleep mode is 'High' even when the energy consumption level is set to 'Low'.
A job is being processed (including a report).
Any of the following settings are set from the Settings/Registration screen:
[Preferences]
[Network]
[NetWare Settings]
<Use NetWare> is set to 'On'.
[IEEE 802.1X Settings]
<Use IEEE 802.1X> is set to 'On'.
