e-ManualTopSite mapHelp
Category Top
Flow of Operations on the Settings/Registration Screen
Flow of Operations for Administrators
Flow of Operations for General Users
Settings/Registration Table
Preferences
Adjustment/Maintenance
Function Settings
Function Settings: Printer
Function Settings: Store/Access Files
Function Settings: Secure Print
Function Settings: Web Access
Management Settings
Preferences
Paper Settings
Registering the Paper Size and Type for a Paper Source
Setting the Paper Size Group for Auto Recognition in the Paper Source
Distinguishing A5 and STMT Paper
Registering/Editing Custom Paper Types
Registering Multi-Purpose Tray Default Settings
Registering/Editing/Deleting Custom Paper Sizes
Display Settings
Default Screen after Startup/Restoration
Default Screen (Status Monitor/Cancel)
Store Location Display Settings
Enabling the Language/Keyboard Switch
Changing the Display Language/Keyboard on the Touch Panel Display
Changing the Keyboard Shift Lock Feature Settings
Displaying the Remaining Paper Message
Number of Copies/Wait Time Status Display
Setting the Default Display of the Paper Type Selection Screen
mm/Inch Entry Switch
Displaying the Current Department ID/User Name
Displaying the Remaining Toner Error Message
Deleting the Remaining Toner Error Message
Timer/Energy Settings
Current Time Adjustment
Current Date and Time
Time Format
Quick Startup Settings
Auto Reset Time
Default Display after Auto Reset
Auto Sleep Time
Energy Consumption in the Sleep Mode
Auto Sleep Weekly Timer Settings
Setting the Sleep Mode Exit Time
Accessibility
Key Repetition Settings
Inverting the Screen Colors
Adjust Image Quality
Adjusting Gradation and Density
Auto Correct Color Mismatch
Dither Pattern Settings
Reducing Toner Used When Color Printing
Correcting Irregularities in Shaded Areas
Function Settings
Common
Paper Feed Settings
Enabling Paper Drawer Auto Selection
Matching the Print Side for 1-Sided and 2-Sided Printing
Enabling Timeout for Suspended Jobs
Paper Output Settings
Alternating the Print Output (Offset Jobs)
Inserting a Job Separation Sheet between Print Jobs
Inserting a Job Separation Sheet between Copy Sets
Print Settings
Setting the Printing Priority
Outputting Reports with Two-Sided Printing
Registering/Editing/Deleting User-Defined Text for Page Numbers and Watermarks
Access Files
Common Settings
Specifying the Stored File Settings
Memory Media Settings
Top » Settings/Registration » Settings/Registration Table » Management Settings
Management Settings
0UKW-03C
Management Settings
Management Settings: User Management
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[System Manager Information Settings]
System Manager ID (Seven digits maximum)
7654321
Yes
Yes
System Manager PIN (Seven digits maximum)
7654321
Yes
Yes
System Manager
(NULL)
Yes
Yes
E-Mail Address
(NULL)
Yes
Yes
Contact Information
(NULL)
Yes
Yes
Comment
(NULL)
Yes
Yes
[Department ID Management]
Department ID Management: On, Off
Off
Yes
Yes
Register PIN: Reg., Edit, Delete, Limit Functions
Yes
Yes
Page Totals: Clear, Print List, Clear All Totals
Yes
No
Allow Printer Jobs with Unknown IDs: On, Off
On
Yes
Yes
Allow Black Print Jobs: On, Off
Off
Yes
Yes
Allow Black Printer Jobs: On, Off
Off
Yes
Yes
Management Settings: Device Management
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[Device Information Settings]
Device Name
Model Name
Yes
No
Location
(NULL)
Yes
No
[Device Information Delivery Settings]
[Register Destinations]
Auto Search/Register, Reg., Details, Delete, Print List
No
No
Auto Search/Register:
Search Depth (Router): 1 to 8
1
No
No
Display Host Name: On, Off
Off
No
No
Start Auto Search
No
No
[Set Auto Delivery]
Everyday (1 to 5), Specify Days (Sun to Sat, 1 to 5), Off
Off
No
No
Settings/Registration Value: On, Off
Network Settings: Include, Exclude
Off
Network Settings: Exclude
No
No
Dept. ID: On, Off
Off
No
No
Web Access Favorites*1: On, Off
Off
No
No
Printer Settings: On, Off
Off
No
No
Paper Information: On, Off
Off
No
No
[Manual Delivery]
Off
No
No
Dept. ID: On, Off
Off
No
No
Off
No
No
Off
No
No
Off
No
No
[Set MEAP Authentication]
User Name, Password, Login Destination
No
No
[Restrict Receiving Device Information]
On, Off
On
No
No
[Restore Data]
Settings/Reg. Value, Dept. ID, Address Book, Web Access Favorites*1, Printer Settings, Paper Information, Start
No
No
[Restrict Receiving for Each Function]
On
No
No
Dept. ID: On, Off
On
No
No
On
No
No
On
No
No
On
No
No
[Communication Log]
Details, Print List, Report Settings
No
No
Report Settings
Auto Print (100 Transmissions): On, Off
On
No
No
Specify Print Time: On, Off
Off
No
No
00:00 to 23:59
00:00
No
No
Separate Report Type: On, Off
Off
No
No
[Limited Functions Mode]*1
On, Off
Off
No
No
[Certificate Settings]
[Generate Key]
Key Name
(NULL)
Yes
No
Signature Algorithm: SHA1, SHA256, SHA384, SHA512
SHA1
Yes
No
Key Algorithm: RSA, ECDSA
RSA
Yes
No
When RSA is selected
Key Length (bit): 512, 1024, 2048, 4096
512
Yes
No
When ECDSA is selected
Key Type: P256, P384, P521
P256
Yes
No
Validity Start Date: Month, Date, Year (01/01/2000 - 12/31/2037)
(NULL)
Yes
No
Validity End Date: Month, Date, Year (01/01/2000 - 12/31/2037)
(NULL)
Yes
No
Country/Region: Country/Region name and code
United States (US)
Yes
No
State
(NULL)
Yes
No
City
(NULL)
Yes
No
Organization
(NULL)
Yes
No
Organization Unit
(NULL)
Yes
No
Common Name (IP address of the machine or FQDN (41 characters maximum))
(NULL)
Yes
No
[Key and Certificate List]
Certificate Details: (Version, Serial Number, Signature Algorithm, Issue Destination, Validity Start Date, Validity End Date, Issuer, Public Key, Certificate Thumbprint, Verify Cert.)
Yes
No
Delete
Yes
No
Display Use Location (Key and Certificate)
Yes
No
[CA Certificate List]
Yes
No
Delete
Yes
No
[Certificate Revocation List (CRL)]
CRL Details: Serial Number, Expires, Verify CRL
Yes
No
Delete
Yes
No
[Register Key and Certificate]
Register
Yes
No
Delete
Yes
No
[Register CA Certificate]
Register
Yes
No
Delete
Yes
No
[Display Job Status Before Authentication]
On, Off
On
Yes
No
[Display Log]
On, Off
On
Yes
No
Off
Obtain Job Log with Management Software: Allow, Do Not Allow
Do Not Allow
Yes
No
[Save Audit Log]
On, Off
Off
Yes
No
[Store Key Operation Log]
On, Off
Off
Yes
No
[Format Encryption Method to FIPS 140-2]
On, Off
Off
Yes
No
*1
Indicates items that appear only when the appropriate optional equipment is available for use.
Management Settings: License/Other
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[Register License]
24 characters maximum, Start
(NULL)
No
No
[MEAP Settings]
[Print System Information]
Yes, No
No
No
[Use SSL]
On, Off
Off
Yes
No
[Remote UI]
On, Off
Off
No
Yes
On
Access by General User: Allow, Do Not Allow
Do Not Allow
No
No
Access PIN (seven digits)
No
No
Use SSL:
On, Off
Off
Yes
No
[Delete Message Board Contents]
Yes, No
No
No
[Remote Operation Settings]
On, Off
Off
Yes
No
[Use ACCESS MANAGEMENT SYSTEM]*1
On, Off
Off
Yes
No
[Register/Update Software]
Install Applications/Options, Software Management Settings
Yes
No
[Start Setup Guide]
Start
No
No
*1 Indicates items that appear only when the ACCESS MANAGEMENT SYSTEM KIT is activated.
Management Settings: Data Management
Item
Setting Description
Default Setting
Can be set in Remote UI
Device Information Delivery Available
[Delete Existing Data Settings]
[Delete Existing Data]
On, Off
Off
Yes
No
[Timing of Deletion]
During Job, After Job
During Job
Yes
No
[Overwrite Method to Delete HDD Data]
Once with 0 (Null) Data, Once with Random Data, 3 Times with Random Data, DoD Standard
Yes
No
[Initialize All Data/Settings]
Once with 0 (Null) Data, Once with Random Data, 3 Times with Random Data, 9 Times with Random Data, DoD Standard
No
No
[TPM Settings]
Use TPM: On, Off
Off
No
No
Back Up TPM Key(12 characters maximum for password), Restore TPM Key
No
No
