RX Result Report (imageRUNNER 1435iF Only)
You can print a report to check the details of a received fax. The report can be printed each time you receive a fax, or only when a receiving error occurs.
<Off>
Select if you do not want to print the report.
<On>
Select to print the report each time you receive a fax.
<Only When Error Occurs>
Select to print the report only when a receiving error occurs.
Example:
Result
"OK" indicates that the fax was received successfully while "NG" and three digits (an error code) indicates that the fax communication failed (
When an Error Code Appears).
