Top
Site Map
Help
Print
Contents
Search
Maintenance
Expand All
Collapse All
Maintenance
Cleaning the Machine
Exterior
Platen Glass
Feeder (imageRUNNER 1435iF / 1435i Only)
Fixing Assembly
Transfer Roller
Drum Unit
Replacement Parts
Replacing the Toner Cartridge
How to Replace the Toner Cartridge
Replacing the Drum Unit
Maintaining and Improving Print Quality
Adjusting the Copy Image
Adjusting the Print Density
Saving Toner
Adjusting the Text Color Reproducibility in Color Documents
Printing Reports and Lists
Fax TX Result Report (imageRUNNER 1435iF Only)
E-Mail/File TX Result Report (imageRUNNER 1435iF / 1435i Only)
Communication Management Report (imageRUNNER 1435iF / 1435i Only)
RX Result Report (imageRUNNER 1435iF Only)
Department ID Management Report
Address Book List (imageRUNNER 1435iF / 1435i Only)
User Data List
System Manager Data List
IPSec Policy List
PCL Font List
PS Font List
Viewing the Counter Value
Using a USB Memory Device to Export/Import Registered Data
Exporting Registered Data to a USB Memory Device
Importing Registered Data from a USB Memory Device
Initializing Settings
Initializing Menu
Initializing Key and Certificate
Initializing Address Book (imageRUNNER 1435iF / 1435i Only)
Initializing System Management Settings
Initializing After Replacing Parts (imageRUNNER 1435iF / 1435i Only)
Print all
Search options
Search all chapters
Search from below chapters
Important Safety Instructions
Basic Operations
Copying
Faxing (imageRUNNER 1435iF Only)
Using the Machine as a Printer
Using the Machine as a Scanner
Can Be Used Conveniently with a Mobile Device
Network
Security
Using the Remote UI
Setting Menu List
Troubleshooting
Maintenance
Appendix
Case sensitive
Differentiate between one-byte and two-byte
Search with these conditions
Top
Maintenance
PS Font List
0KCF-0E4
PS Font List
You can print a list to check the fonts available in PS mode.
The PS font list can only be printed for the imageRUNNER 1435iF, or the imageRUNNER 1435i / 1435 with the optional PS Printer Kit enabled.
<Output Reports>
<Print List>
<PS Font List>
Check that the size and type of paper displayed on the screen is loaded in the machine
<Yes>
Example:
