Maintenance
0KCF-0CY
Department ID Management Report
When Department ID Management is enabled, you can print a report to check the total number of pages that were copied, printed, and scanned for each Department ID. The report enables you to monitor usage and improve management.
Example:
1
Press .
2
Use / to select <Output Reports>, and press .
3
Select <Print List>  <Department ID Management Report>.
If the logon screen appears, enter the correct ID and PIN using the numeric keys, and then press . Logging on to the Machine
4
Check that the size and type of paper displayed on the screen is loaded in the machine, and press .
5
Select <Yes>, and press .
