When the drum unit inside the machine becomes dirty, print quality may deteriorate. If this happens, follow the procedure below to clean the drum unit. Note that you cannot clean the drum unit when the machine has documents waiting to be printed.
1
Press
2
Use
to select <Adjustment/Maintenance>, and press
3
Select <Clean Drum Unit>, and press
4
Press
Cleaning starts. When the <Finished.> message is displayed approximately 1 minute later, press
to return to the main screen.
