When the fixing assembly inside the machine becomes dirty, black streaks may appear on printouts. If this happens, follow the procedure below to clean the fixing assembly. Note that you cannot clean the fixing assembly when the machine has documents waiting to be printed.
1
Press
2
Use
to select <Adjustment/Maintenance>, and press
3
Select <Clean Fixing Assembly>, and press
4
Check that the size and type of paper displayed on the screen is loaded in the machine, and press
Cleaning starts. When the <Finished.> message is displayed approximately 2 minutes later, press
to return to the main screen.
LINKS
