Regularly wipe off the dust from the platen glass and the underside of the feeder or platen glass cover to ensure that documents are scanned clearly.
Turn OFF the machine, and unplug the power cord from the AC power outlet.
When you turn OFF the machine, data that is waiting to be printed is deleted. However, fax documents that were received by using the Memory Reception function, faxes that are waiting to be sent, and reports that are automatically printed after sending and receiving faxes are not deleted.
Open the feeder or the platen glass cover.
Clean the platen glass and the underside of the feeder or platen glass cover.
Clean the areas with a well-wrung-out cloth dampened with water. Then, wipe the area with a soft, dry cloth.
Wait for the cleaned area to dry completely.
Gently close the feeder or the platen glass cover.
Reconnect the power cord and turn ON the machine.
