E-Mail/File TX Result Report (imageRUNNER 1435iF / 1435i Only)
You can print a report to check the result of a transmission sent by e-mail or saved in a file server. The report can be printed either each time a transmission is completed or only when a sending error occurs.
<Off>
Select if you do not want to print the report.
<On>
Select to print the report each time you send a scanned document.
<Only When Error Occurs>
Select to print the report only when a sending error occurs.
Example:
Department ID
The Department ID is shown when Department ID Management is enabled.
Sent/Error
The name and address or host name of the destination are displayed. If you sent the document by e-mail, the report indicates the transmission result between the machine and the mail server, not between the machine and the destination address. A three-digit error code will not be printed, even if the transmission failed. To check the error code, print a Communication Management Report (
Communication Management Report (imageRUNNER 1435iF / 1435i Only)).
