Maintenance
0KCF-0E9
Initializing Address Book (imageRUNNER 1435iF / 1435i Only)
You can restore the Address Book settings to the factory defaults. Note that all the information registered in the Address Book will be deleted after initializing.
1
Press .
2
Use / to select <System Management Settings>, and press .
If the logon screen appears, enter the correct ID and PIN using the numeric keys, and then press . Logging on to the Machine
3
Select <Initialize Address Book>, and press .
4
Select <Yes>, and press .
