      0KCF-0CR
      Printing Reports and Lists
      You can print reports and lists to check the communication results, the settings registered in the machine, the available fonts, and other information.
      Fax TX Result Report
      You can check the result of a fax transmission. Fax TX Result Report (imageRUNNER 1435iF Only)
      E-Mail/File TX Result Report
      You can check the result of a transmission sent by e-mail or saved in a file server. E-Mail/File TX Result Report (imageRUNNER 1435iF / 1435i Only)
      Communication Management Report
      You can check the log of sending/receiving results. Communication Management Report (imageRUNNER 1435iF / 1435i Only)
      RX Result Report
      You can check the details of a received fax. RX Result Report (imageRUNNER 1435iF Only)
      Department ID Management Report
      You can check the total number of pages that were used by each Department ID. Department ID Management Report
      Address Book List
      You can check the details of destinations registered in the Address Book. Address Book List (imageRUNNER 1435iF / 1435i Only)
      User Data List
      You can check the list of setting items (Setting Menu List) and current settings registered in the machine. User Data List
      System Manager Data List
      You can check the details for <Network Settings> and <System Management Settings> in addition to the information in the User Data List. System Manager Data List
      IPSec Policy List
      You can check the policy names and IPSec settings currently registered in the machine. IPSec Policy List
      PCL Font List
      You can check the fonts available in PCL mode. PCL Font List
      PS Font List
      You can check the fonts available in PS mode. PS Font List
