You can set the machine to prompt you to clean the scanning area when the feeder is dirty. The prompt appears when documents are placed in the feeder.
TIPS
If you want to reduce the visibility of streaks caused by dust on the scanning area:
1
Open the feeder cover.
2
Clean the rollers (two locations) inside the feeder cover. Spin the rollers while cleaning them.
1
Place your finger in the hole indicated by the green mark, and lift the inner cover.
2
Clean the transparent plastic (two locations).
1
Open the feeder.
2
Wipe the white strip of plate (
