Do not turn OFF the machine until the export/import process is complete
It may take a few minutes to complete the process. If the machine is turned OFF during the process, it may result in damage to data or the machine.
Do not operate the machine during the export/import process
Before exporting/importing, check that no operations such as printing documents are currently in progress.
Do not use non-standard USB memory devices. You may not be able to export/import data properly with some USB memory devices.
Do not connect anything other than a USB memory device. USB memory devices cannot be connected via a USB hub or an extension cable.
Do not use USB memory devices with special functions such as built-in security functions.
