Communication Management Report (imageRUNNER 1435iF / 1435i Only)
You can print a report to check the log of sending/receiving results. The report can be printed automatically after every 40 transmissions or it can be printed manually.
<Auto Print (40 Transmissions)>
Select <On> to print the report automatically after every 40 transmissions, or <Off> if you do not want to print the report automatically.
<Separate TX/RX>
Select <On> to print the sending results and receiving results separately, or <Off> to print both results on one sheet.
Printing the Report Manually
Example:
Result
"OK" indicates that the transmission was completed successfully while "NG" and three digits (an error code) indicates that the transmission failed (
When an Error Code Appears). For documents sent by e-mail, the report indicates the transmission results between the machine and the mail server, not between the machine and the destination address.
