[Setup] Menu ([User Maintenance] Options)
Table description
Bold values in the table indicate the default settings.
The setting items or setting values with "*" may not be displayed depending on the availability of the optional accessories and other settings.
Setting Item
Setting Value
Setting
[Adj. Start Position]
[Offset Y (MP Tray)]: -0.20 to 0.00 to +0.20 (in.)
[Offset X (MP Tray)]: -0.09 to 0.00 to +0.09 (in.)
[Offset Y (Drawer 1)]: -0.20 to 0.00 to +0.20 (in.)
[Offset X (Drawer 1)]: -0.09 to 0.00 to +0.09 (in.)
[Offset Y (Drawer 2)]*: -0.20 to 0.00 to +0.20 (in.)
[Offset X (Drawer 2)]*: -0.09 to 0.00 to +0.09 (in.)
[Offset Y (2-Sided)]: -0.20 to 0.00 to +0.20 (in.)
[Offset X (2-Sided)]: -0.09 to 0.00 to +0.09 (in.)
Specifies the printing position of the paper in the specified paper source. Adjusts the position in the vertical direction (Y) or the horizontal direction (X) by the specified value.
The setting values are indicated in inches (in.), and you can adjust the position using [  ] and [  ].
If you do not adjust the printing position, specify [0.0] for this item.
Adjust the printing position for 2-sided printing as follows.
Adjust the printing position of the first page using [Offset Y (2-Sided)] and [Offset X (2-Sided)].
The printing position of the second page depends on the settings for each paper source.
If any part of the print image lies outside the printable area after adjusting the printing position, the part will be missing in the print result.
[Recovery Printing]
[Off], [On]
Specifies whether to print the partially printed page when the printer stops printing due to a paper jam or an error occurring.
[Check Paper Size]
[Off], [On]
Specifies whether the printer should stop printing, displaying the message <Check paper size.> or continue printing when [MP Tray Paper Size], [Drawer 1 Size], [Drawer 2 Size] is set to [Mixed Sizes].
[Substitute Size]
[Off], [On]
When the paper of the target size is not loaded in the printer, the printer prints on paper of the following sizes.
Size of the Paper to Be Printed
Printer Driver Setting
Letter
A4
A4
Letter
[Special Image Mode]
[Off], [Level 1], [Level 2]
If the centers of dense text or lines are not being printed, set this to [Level 1].
If the problem still persists after setting it to [Level 1], set it to [Level 2].
When [Special Image Mode] is used, the print density becomes lower.
[SD Card Maintenance]
[Format]
[No], [Yes]
Delete the contents of the SD card.
[Special Print Mode]
[Curl Correction]
[Off], [On]
When printed paper curls, set this item to [On].
[Smooth Plain Paper]
[Off], [On]
If plain paper with a smooth surface is used, the density may be low. In such a case, set this item to [On] to improve this problem.
Normally, use the printer with this option set to [Off]. Change the setting for this option only if the above phenomenon occurs.
[Update Firmware]
[USB]
This option is to be executed only when the firmware of the printer needs to be updated.
[Network]
[First Calibration]
[Off], [After Jobs], [Immediately]
Specify the timing of calibration.
If [After Jobs] is specified, calibration is performed at the completion of the first printing after the printer is turned on.
If [Immediately] is specified, calibration is performed immediately after the printer is turned on.
When calibration is performed immediately after the printer is turned on, excessive time is required until the printer is ready to print.
[Paper Feed Method]
[Multi-Purpose Tray]: [Speed Priority], [Print Side Priority]
[Drawer 1]: [Speed Priority], [Print Side Priority]
[Drawer 2]*: [Speed Priority], [Print Side Priority]
Specifies on which side of the loaded paper the printer should print.
Perform printing after selecting the paper drawer or tray to feed paper. Select the paper source.
The setting of this item determines which side of paper is printed on. Load the paper in proper orientation.
If [Speed Priority] is specified, the printing sides of the paper for 1-sided printing and 2-sided printing do not match.
If you specify [Print Side Priority], the printer matches the printing sides of the paper for 1-sided printing and 2-sided printing. Therefore, when you print previously printed paper, you do not need to reload the paper each time you switch between the settings.
If you specify [Print Side Priority], the print speed drops.
[Adjust Standby Temp]
[Off], [Mode 1], [Mode 2], [Mode 3]
Specify whether or not to adjust the temperature of the fixing unit during standby. If other than [Off] is specified, the time to start printing from the standby state becomes shorter compared to when [Off] is specified.
[Mode 1]
(Time to start printing from the standby state: shorter/power consumption: larger, compared to when [Off] is specified)
[Mode 2]
[Mode 3]
(Time to start printing from the standby state: shortest/power consumption: largest)
If other than [Off] is specified, the power consumption during standby becomes larger compared to when [Off] is specified.
[Show Job List]
[Off], [On]
Specifies whether to display the job list when [  ] (Job Status/Cancel) is pressed.
If [On] is specified, the printer displays the job list.
If [Off] is specified, the printer does not display the job list.
[IMPORT/EXPORT]
[EXPORT], [IMPORT]
You can save and read printer settings.
» Managing the Printer » Setting Items » [Setup] Menu ([User Maintenance] Options)
07E3-0XK
