Table description
Bold values in the table indicate the default settings.
After changing the setting items with "*1", cycle the power of the printer or perform a hard reset to make the settings effective.
The setting items or setting values with "*2" may not be displayed depending on the availability of the optional accessories and other settings.
Setting Item
Setting Value
Setting
[Interface Selection]*1
[USB]: [Off], [On]
[Network]: [Off], [On]
[USB Storage Device]: [MEAP Driver]: [Off], [On]
Specifies the settings for the interfaces used for communication with the computer and so on.
You can specify [On] or [Off] for each interface.
[Timeout]
[Timeout]: [Off], [On]
[Timeout Time]*2: 5 to 15 to 300 seconds
Specifies the function to finish a job automatically.
[Connection Recog.]*1
[Off], [On]
When you print using the standard network, you may not obtain proper printout results. (Unreadable characters are printed, overlay printing fails, etc.) In this case, specify [Off] for this item.
[Extended RX Buffer]*1
[Off], [On]
If this item is set to [On], the memory capacity of the printer's receive buffer that receives the data is increased. You can speed up the time the computer exits when you send a large amount of data or complicated data from the computer.
