Deleting the print logs
The print logs are deleted by turning the printer OFF or performing a hard reset.
About [Document Name]
A job file name of up to 32 characters can be displayed. If the file name has more than 32 characters, the characters after the limited number are not displayed.
Also, depending on the application, the application name may be added to the beginning of the file name. About the job histories
The maximum numbers of the print logs that you can check are as follows. When the number of the jobs exceeds the maximum, the job histories are deleted starting from the oldest one.
[Print Job/Direct Print]: 48 (200 when SD card is installed)
[Stored Job]: 128 (only when SD card is installed)
[Report]: 16 (128 when SD card is installed)
[E-Mail Print]: 16 (128 when SD card is installed)
If the jog log display is not specified in [Display Job History] in the [Settings/Registration] - [Management Settings] - [Security] page, you cannot display the job histories.
