Table description
Bold values in the table indicate the default settings.
The setting items or setting values with "*" may not be displayed depending on the availability of the optional accessories and other settings.
Setting Item
Setting Value
Setting
[Paper Save]
[Off], [On]
Specifies whether the printer outputs the blank page that can be created due to no data existing between two Form Feed codes sent from an application.
[Orientation]
[Portrait], [Landscape]
Enables you to set the paper orientation.
[Font Number]
0 to 104
Enables you to set the default font for this printer function using the corresponding font numbers. Valid font numbers are from 0 to 104.
[Point Size]*
4.00 to 12.00 to 999.75 point
If the number selected in [Font Number] is that of a proportionally spaced scalable font, this option appears in the [PCL] options. It enables you to specify a point size for the default font. The point size can be adjusted in increments of 0.25 pts.
[Pitch]*
0.44 to 10.00 to 99.99 cpi
If the number selected in [Font Number] is that of a fixed pitch scalable font, Pitch appears in the [PCL] options. It enables you to specify the pitch for the default font. The pitch can be adjusted in increments of 0.01 cpi (characters per inch).
[Form Lines]
5 to 60 to 128 lines
Enables you to specify the number of lines to be printed on a page. You can specify from 5 to 128 lines.
[Character Code]
[PC8], [ROMAN8], [ROMAN9], [ISOL1], [ISOL2], [ISOL5], [ISOL6], [ISOL9], [PC775], [PC8DN], [PC850], [PC852], [PC858], [PC8TK], [PC1004], [WINL1], [WINL2], [WINL5], [WINBALT], [DESKTOP], [PSTEXT], [LEGAL], [ISO4], [ISO6], [ISO11], [ISO15], [ISO17], [ISO21], [ISO60], [ISO69], [WIN 30], [MCTEXT], [PC864], [ARABIC8], [WINARB], [PC866], [ISOCYR], [WINCYR], [PC851], [GREEK8], [ISOGRK], [PC8GRK], [WINGRK], [PC862], [HEBREW7], [HEBREW8], [ISOHEB]
Enables you to select the symbol set most suited to the needs of the host computer.
[Custom Size]
[Do Not Set], [Set]
Enables you to specify a custom paper size. If [Set] is selected, you can enter a custom size.
[Unit of Measurement]*
[Millimeters], [Inches]
Enables you to specify the unit of measurement you would like to use to specify your custom paper size.
[X Dimension]*
3.00 to 8.50 in.; 8.50 in. (76.2 to 215.9 mm; 215.9 mm)
Enables you to specify the X dimension of the custom paper. The X dimension can be adjusted between 3.00 in. (76.2 mm) and 8.50 in. (215.9 mm) in increments of 0.01 in. (0.1 mm).
[Y Dimension]*
5.00 to 14.00 in.; 14.00 in. (127.0 to 355.6 mm; 355.6 mm)
Enables you to specify the Y dimension of the custom paper. The Y dimension can be adjusted between 5.00 in. (127.0 mm) and 14.00 in. (355.6 mm) in increments of 0.01 in. (0.1 mm).
[Append CR to LF]
[Yes], [No]
Enables you to specify whether to append a carriage return (CR) when line feed code (LF) is received.
[Enlarge A4 Prt Width]
[Off], [On]
Determines whether to expand the printable area of A4 paper to that of Letter size in width.
[BarDIMM]*
[Enable], [Disable]
You can enable or disable the Bar Code Printing function of the printer.
[FreeScape]*
[Off], [~], ["], [#], [$], [/], [\], [?], [{], [}], [|]
You can specify the AEC (Alternate Escape Code) to be used for bar code commands when the host computer does not support the standard Escape Code.
