Automatically Performing Calibration Immediately after the Printer Is Turned ON
You can set the timing for performing calibration when the self-diagnostic immediately after the printer is turned ON determines that calibration is necessary.
1
Press [  ] (Online).
The Online indicator goes off, allowing you to specify the settings on the control panel.
2
Press [  ] (Settings).
3
Select [User Maintenance] using [ ] and [ ], and then press [OK].
4
Select [First Calibration] using [ ] and [ ], and then press [OK].
5
You can configure the printer operation that is run immediately after the printer is turned ON.
Select [After Jobs] or [Immediately] with [ ] or [ ], and press [OK].
After Jobs
It runs color mismatch adjustment after the first print job after the printer is turned ON is completed.
Immediately
Print color mismatch is adjusted immediately after the printer is turned ON. If color mismatch adjustment is run immediately after the printer is turned ON, it will take some time before it is possible to print.
The setting for [First Calibration] is changed.
» Maintenance » Cleaning and Maintaining the Printer » Adjusting the Color or Color Mismatch (Calibration) » Automatically Performing Calibration Immediately after the Printer Is Turned ON
07E3-0WL
