e-ManualTopSite mapHelp
Chapter Top
Software That Can Be Used for Managing the Printer
Remote UI
Starting the Remote UI
Attention (Remote UI)
Enabling the Remote UI
Screen Layout of the Remote UI (Details on Each Setting Page)
Display/Change Message Board Messages and Support Links
FTP Client
NetSpot Device Installer
Managing Print Jobs
Attention (Job Manager)
Control Panel Setting
Attention (Control Panel Setting)
Setting Items
[Setup] Menu ([Control Menu] Options)
[Setup] Menu ([Paper Source] Options)
[Setup] Menu ([Network] Options)
[Setup] Menu ([Layout] Options)
[Setup] Menu ([Quality] Options)
[Setup] Menu ([Interface] Options)
[Setup] Menu ([User Maintenance] Options)
[Setup] Menu ([Print Mode] Options)
[Setup] Menu ([UFR II] Options)
[Setup] Menu ([PCL] Options)
[Setup] Menu ([Imaging] Options)
[Setup] Menu ([XPS] Options)
[Setup] Menu ([PDF] Options)
[Setup] Menu ([PS] Options)
[Setup] Menu ([MEAP Settings] Options)
[Setup] Menu ([Check Counter] Options)
[Utility Menu] Menu
[Job] Menu
[Reset] Menu
[Select Feeder] Menu
Checking the Number of the Printed Pages
Importing and Exporting Settings
Initializing the Settings
Initializing the [Setup] Menu Using the Printer's Control Panel
Checking the Printer Settings
Setting the Administrator Password
Specifying the Device Name or Administrator Information
Sleep Mode
Auto Shutdown
Specifying an ID for Each Department
Register/Update Software Function
Available Functions
Installing the System Options/MEAP Applications
Installing by Connecting This Printer to an Outside Network (Delivery)
Installing by Not Connecting This Printer to an Outside Network (Manual)
Downloading the Manuals and Related Software
Managing the Register/Update Software Function
Top » Managing the Printer » Checking the Number of the Printed Pages
07E3-0Y0
If you want to check the number of the printed pages, use either of the following methods.
Checking the Counter Using the Printer's Control Panel
You can check the number of the printed pages using the control panel.
1
Press [ ] (Settings).
2
Select [Check Counter] using [  ] or [  ], and then press [OK].
3
Select the counters to check using [  ] and [ ], and then press [OK].
4
Check the number of the printed pages.
Checking the Counter Using a Web Browser (Remote UI)
You can check the number of the printed pages using the Remote UI.
1
Start the Remote UI, and then log in as Administrator.
2
Select [Check Counter] from the [Status Monitor/Cancel] menu.
3
