In the Remote UI, you can specify the settings by accessing the printer from a Web browser via a network.
When specifying the settings using software other than the Remote UI
You can also specify the settings using the following software.
You can specify the settings by accessing the FTP server of the printer using Command Prompt.
(1)
Select the [Set/Change Password] check box.
(2)
Enter the administrator password.
(3)
Click [OK].
Select the check box when setting/changing the password.
[Password]
Enter a new desired password.
[Confirm]
To confirm the password, enter the password entered in [Password] again.
