e-ManualTopSite mapHelp
Top » Paper Type Management » Adjusting the Creep (Displacement) Correction
0L3X-0HC
If you want to change the creep (displacement) correction for each page in a booklet, adjust the creep correction width for the registered custom paper type.
For more information on creep (displacement), see "Booklet Mode" in "Copy" and "Booklet Mode" in "Access Stored Files."
The value set in this mode is used as the default value for the automatic creep (displacement) correction in the Saddle Stitching mode.
Press [Preferences] → [Paper Settings] → [Paper Type Management Settings].
Select the paper type that you want to edit from the list → press [Details/Edit].
4.
Press [Change] for <Adjust Creep Correction>.
5.
Press [] or [] to adjust the correction width → [OK].
6.
Press [OK].
