e-ManualTopSite mapHelp
Top » Paper Type Management » Adjusting the Paper Curve Setting
0L3X-0HW
The paper curve is a deflection which occurs in paper when adjusting the image position. If the printed image is skewed, the output paper is creased, or the lead edge/tail end of the paper is curled, you may be able to correct them by adjusting the setting value of the paper curve.
This function is displayed only if the settings are made available by your local authorized Canon dealer. Even if this function is displayed, do not allow anyone to change the settings except for the system manager. For more information on changing the settings, contact your local authorized Canon dealer.
Press [Preferences] → [Paper Settings] → [Paper Type Management Settings].
Select the paper type that you want to edit from the list → press [Details/Edit].
4.
Press [Change] for <Adjust Paper Curve>.
5.
Press []or [] to adjust the paper curve → [OK].
To correct the distorted image, increase the setting value.
To correct the paper creasing, curving mark, or curled edges of paper, decrease the setting value.
6.
Press [OK].
