Adjusting the Fixing Pressure
0L3X-0JE
When using long originals, envelopes, paper which has absorbed moisture, or thin paper, paper feeding troubles may occur or the quality of the image may be adversely affected. If these conditions are not improved even after adjusting the fixing speed, adjust the fixing pressure.
This function is displayed only if the settings are made available by your local authorized Canon dealer. Even if this function is displayed, do not allow anyone to change the settings except for the system manager. For more information on changing the settings, contact your local authorized Canon dealer.
Press
(Settings/Registration).
Press [Preferences] → [Paper Settings] → [Paper Type Management Settings].
Select the paper type that you want to edit from the list → press [Details/Edit].
4.
Press [Change] for <Adjust Fixing Pressure>.
5.
Press [-] or [+] to adjust the fixing pressure → [OK].
If the result is unsatisfactory even after pressing [+], press [-].
6.
Press [OK].
