This function is displayed only if the settings are made available by your local authorized Canon dealer. Even if this function is displayed, do not allow anyone to change the settings except for the system manager. For more information on changing the settings, contact your local authorized Canon dealer.
Adjusting the Secondary Transfer Antistatic Bias may affect the settings in [Adj. Secondary Transfer Volt.], [Adjust ITB Image Clearing], and [Corr. Tail End Toner Applic.]. Readjust these settings, if necessary.
(Settings/Registration).|
If the result is unsatisfactory even after pressing [-], press [+].
If the condition is not improved even after adjusting the value in both [-] and [+] directions, adjust the setting value in [Adj. Secondary Transfer Volt.]. The condition may be improved by adjusting the Secondary Transfer Voltage value toward [-] side.
