To make sure that the [Saddle Press] setting is effective, you must saddle stitch more than nine sheets of paper (including one cover sheet).
This mode can be used only for printing a file stored in a mail box or a PDF file.
The Saddle Stitch and Divided Booklet modes can be set only if the Saddle Finisher-AM2/Booklet Finisher-T1 is attached.
The Saddle Press mode can be set only if the Saddle Finisher-AM2 is attached.
The Trim mode can be set only if the Booklet Trimmer-D1 or the Two-Knife Booklet Trimmer-A1 is attached to the Saddle Finisher-AM2.
Be sure to correctly set the paper type. When printing on special types of paper, such as heavy paper, be sure to correctly set the paper type, especially if you are using heavy paper. If the type of paper is not set correctly, it could adversely affect the quality of the image. Moreover, the fixing unit may become dirty and require a service repair, or the paper could jam.
[Booklet Scan] can only be specified for the following paper sizes: LTR, LTRR, STMT, or STMTR.
The Booklet mode cannot be set if multiple files are selected, and their record sizes are different.
The Booklet mode cannot be set if multiple documents are selected, and their resolution is different.
Mail Box
Memory Media
Fold can be used only for printing a file stored in a mail box.
The following shows the maximum number of sheets that can be saddle stitched at a time. If you want to saddle stitch the more sheets, set the Divided Booklet mode, otherwise the booklet is not saddle stitched.
If the Saddle Finisher-AM2 is attached: 25 sheets
If the Booklet Finisher-T1 is attached: 16 sheets
The following shows the maximum number of sheets that can be folded at one time when [Fold Only] is selected:
If the Saddle Finisher-AM2 is attached: five sheets
If the Booklet Finisher-T1 is attached: one sheet
You must select the same paper size for the cover page as that used for the main document.
If you load preprinted paper to use as the cover page into the document insertion unit, you must load the paper face up.
If you are using Heavy paper, you can only print on <Front Inside Cover> or <Back Inside Cover>.
The following shows the paper weight that you can use when the Saddle Finisher-AM2 is attached.
For the cover page and main document: 52 g/m2 to 300 g/m2 (14 lb bond to 110 lb cover)
The following shows the paper weight that you can use when the Booklet Finisher-T1 is attached.
For the main document: 60 g/m2 to 220 g/m2 (16 lb bond to 80 lb cover)
For the cover page: 60 g/m2 to 256 g/m2 (16 lb bond to 140 lb index)
[Add Cover] can be used only for printing a file stored in a mail box.
If you are adding a cover, the maximum number of sets that the booklet tray of the Booklet Finisher-T1 can hold is 10.
You can select [Opening Type] only if you set [Booklet Scan].
[Set Details] can be used only for printing a file stored in a mail box.
If the Saddle Finisher-AM2 is attached, the number of saddle stitched booklets that the auxiliary booklet tray can hold depends on the number of sheets each booklet contains, paper size, and whether the booklet includes cover page used heavy paper (106 g/m2 (29 lb bond) or more).
If the Booklet Trimmer-D1 is attached to the Saddle Finisher-AM2, the tray can hold 30 prints.
If the Booklet Finisher-T1 is attached, the number of saddle stitched booklets that the auxiliary booklet tray can hold depends on the paper type, paper weight, and number of sheets each booklet contains.
You can set [Trim] only if you select [Fold + Saddle Stitch].
If you want to register and edit the configured finishing size, press [Reg.].
If you enter a value other than 0, you can switch between the positive and negative adjustment amount by pressing [±].
You can set [Saddle Press ] if you select [Fold + Saddle Stitch].
Increasing the pressure too much may result in a wrinkled or compressed booklet spine, or a paper jam. Increase the pressure level gradually when you adjust the strength of the saddle press.
You can set [Change Fold/Stitch Pos.] only if you select [Fold + Saddle Stitch].
You can set [Adjust Fold Position] only if you select [Fold Only].
305 mm x 457 mm/A3/B4/11" x 17"/LGL
A4R/LTRR
Make sure to set the Booklet Tray guide to match the paper size. Setting the Booklet Tray guide incorrectly may result in a paper jam.
Saddle stitching is not performed if there is only one output sheet.
The accuracy of folds may vary, depending on the type and quantity of paper.
