e-ManualTopSite mapHelp
Top » Paper Type Management » Adjusting the Paper Realignment Speed
0L3X-0HX
The paper realignment speed is the speed for adjusting the image position. If the paper realignment speed is not appropriate, the printed image may become rough or color on the tail end of the paper may change. In this case, adjust the paper realignment speed by pressing [-].
This function is displayed only if the settings are made available by your local authorized Canon dealer. Even if this function is displayed, do not allow anyone to change the settings except for the system manager. For more information on changing the settings, contact your local authorized Canon dealer.
Press [Preferences] → [Paper Settings] → [Paper Type Management Settings].
Select the paper type that you want to edit from the list → press [Details/Edit].
4.
Press [Change] for <Adj. Paper Realignment Speed>.
5.
Press [-] or [+] to adjust the paper realignment speed → [OK].
If the printed image become rough, press [-] to adjust the paper realignment speed.
If color on the tail end of the output paper changes, press [-] to adjust the paper realignment speed. If you do not see any improvement, press [+] to adjust the paper realignment speed.
6.
Press [OK].
