e-ManualTopSite mapHelp
Top » Paper Type Management » Adjusting the Position of Punch Holes
0L3X-0J9
Depending on the paper type, the positions of the punch holes may be slightly different on each piece of paper. In this case, you can make fine adjustments to the positions of the punch holes to compensate this error. For example, if the positions of the punch holes on multiple paper types in the Sheet Insertion mode are not exactly the same, you can use this mode to make fine adjustments.
This function is displayed only if the settings are made available by your local authorized Canon dealer. Even if this function is displayed, do not allow anyone to change the settings except for the system manager. For more information on changing the settings, contact your local authorized Canon dealer.
Press [Preferences] → [Paper Settings] → [Paper Type Management Settings].
Select the paper type that you want to edit from the list → press [Details/Edit].
4.
Press [Change] for <Adjust Hole Punch Position>.
5.
Press [] or [] to adjust the position of punch holes → [OK].
If you want the positions of the punch holes to shift down toward the bottom, increase the setting value.
If you want the positions of the punch holes to shift up toward the top, decrease the setting value.
6.
Press [OK].
