This function is displayed only if the settings are made available by your local authorized Canon dealer. Even if this function is displayed, do not allow anyone to change the settings except for the system manager. For more information on changing the settings, contact your local authorized Canon dealer.
If the result is unsatisfactory even after pressing [+], press [-].
If the condition is not improved even after you have adjusted the value in both [-] and [+] directions, adjust the Secondary Transfer Voltage value. The condition may be improved by adjusting the value of Secondary Transfer Voltage value in the [-] direction. However, note that changing the value of Secondary Transfer Voltage value abruptly may greatly affect the output result. Make sure to check the output result while adjusting the value.
