e-ManualTopSite mapHelp
Top » Paper Type Management » Changing the Finishing Type
0L3X-0H7
You can change the finishing type of the custom paper type.
If you select a finishing type which is different from the actual surface texture of the paper, paper jams may occur, and the quality of the image may be adversely affected.
Press [Preferences] → [Paper Settings] → [Paper Type Management Settings].
Select the paper type that you want to edit from the list → press [Details/Edit].
4.
Press [Change] for <Finish>.
5.
Select the finishing type → press [OK].
6.
Press [OK].
