0L3X-0H6
You can change the size of the custom paper type.
If you select the paper size which is different from the actual paper size, paper jams may occur, and the quality of the image may be adversely affected.
Press
(Settings/Registration).
Press [Preferences] → [Paper Settings] → [Paper Type Management Settings].
Select the paper type that you want to edit from the list → press [Details/Edit].
4.
Press [Change] for <Size>.
5.
Select the paper size.
If you do not want to specify the paper size, press [No Settings].
If you want to select a standard paper size
Select a paper size from <Inch Size> → press [OK].
To select an A or B series paper size, press [A/B Size].
If you want to select a custom paper size
Press [Custom Size].
Press [X] and [Y] → enter each value → press [OK].
You can use the numeric keys to enter values.
You can also select a size key ([S1] to [S5]) containing a stored paper size setting, instead of entering values.
You can register paper types by pressing [Register]. For more information on registering custom paper sizes, see
"Registering/Editing/Deleting Custom Paper Sizes."
Press [OK].
If you want to select an envelope
Press [Envelope].
Select the envelope type.
If you select [Custom], press [Next] and specify the flap position in the feeding direction and envelope size.
Press [OK] → [OK].
If the envelope type is not set correctly, a paper jam may occur.
6.
Press [OK].
