e-ManualTopSite mapHelp
Category Top
Loading Paper
Loading Paper into a Paper Drawer
Adjusting a Paper Drawer to Hold a Different Paper Size
Loading Envelopes
Loading Pre-Punched Paper
Loading Transparencies/Clear Film
Loading Tab Paper
Loading Paper into the POD Deck Lite-B1 (Optional)
Loading Paper into the Multi-drawer Paper Deck-B1 (Optional)
Loading Paper into the Document Insertion Unit-M1 (Optional)
Replacing the Staple Cartridge (For Optional Products)
Replacing the Staple Cartridge in the Stapler Unit (Finisher-AM1/Saddle Finisher-AM2)
Replacing the Staple Cartridge in the Saddle Stitcher Unit (Saddle Finisher-AM2)
Replacing the Staple Cartridge in the Stapler Unit (Staple Finisher-T1/Booklet Finisher-T1)
Replacing the Staple Case in the Saddle Stitcher Unit (Booklet Finisher-T1)
Removing Staple Waste (Finisher-AM1/Saddle Finisher-AM2)
Removing Punch Waste (Puncher Unit-BS1/Puncher Unit-BT1)
Removing Punch Waste (External 2/3 Hole Puncher-C1/External 2/4 Hole Puncher-C1/External 4 Hole Puncher-C1)
Operating the Limited Functions Mode
Replacing the Toner Cartridge
Replacing the Waste Toner Container
Routine Cleaning
Originals Cannot Be Scanned Properly (Cleaning the Platen Glass)
Originals Cannot Be Scanned Properly (Cleaning Method of the Original Scanning Area)
Scanned Originals Become Dirty (Manual Feeder Cleaning)
Scanned Originals Become Dirty (Automatic Feeder Cleaning)
Output Paper Becomes Dirty (Cleaning Inside of the Main Unit)
Output Paper Becomes Dirty (Wire Cleaning)
Output Paper Becomes Dirty (Roller Cleaning)
Output Paper Becomes Dirty (Belt Cleaning)
Streaks and Gloss Unevenness Appear on Output Paper (Refreshing the Fixing Belt)
Streaks and Gloss Unevenness Appear on Output Paper (Adjusting the Fixing Belt Auto Refresh Level)
Cleaning the Touch Panel Display
Consumables
Top » Maintenance » Routine Cleaning » Originals Cannot Be Scanned Properly (Cleaning Method of the Original Scanning Area)
0L3X-0R1
If originals are scanned using the feeder, there may be some cases in which the original cannot be scanned properly, or streaks appear on the copies. In this case, clean the original scanning area by following the directions displayed in [Original Scanning Area Cleaning Method] in [Adjustment/Maintenance] (Settings/Registration).
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
[Adjustment/Maintenance] → [Maintenance] → [Original Scanning Area Cleaning Method].
Follow the instructions on the touch panel display.
