Take care when handling the optional equipment that is attached to the machine. When an optional unit's cover is opened to replace a staple cartridge, discard the punch waste/trim waste/staple waste, or clear paper or staple jams, prints may still be output if other optional units are operating normally, and are not involved in the paper or staple jam removal procedure.
If necessary, remove all of the output paper in the Booklet Tray before replacing the staple cartridge in the saddle stitcher unit.
This procedure is necessary only if the Saddle Finisher-AM2 is attached (the Saddle Finisher-AM2 is an optional product).
When replacing the staple cartridges, replace both the front and back staple cartridges.
We recommend that you order staple cartridges from your local authorized Canon dealer before your stock runs out.
Use only staple cartridges intended for use with this machine.
Follow steps 2 to 7 to replace the other staple cartridge in the saddle stitcher unit.
Always make sure to push the saddle stitcher unit in as far as it can go.
CAUTION |
When pushing the saddle stitcher unit back into its original position, be careful not to get your fingers caught, as this may result in personal injury.
When closing the front cover of the finisher, be careful not to get your fingers caught, as this may result in personal injury.
When you have replaced the staple cartridge, be sure to manually reposition the staples in the saddle stitcher unit. (See "Saddle Stitch Staple Repositioning.")
