e-ManualTopSite mapHelp
Category Top
Loading Paper
Loading Paper into a Paper Drawer
Adjusting a Paper Drawer to Hold a Different Paper Size
Loading Envelopes
Loading Pre-Punched Paper
Loading Transparencies/Clear Film
Loading Tab Paper
Loading Paper into the POD Deck Lite-B1 (Optional)
Loading Paper into the Multi-drawer Paper Deck-B1 (Optional)
Loading Paper into the Document Insertion Unit-M1 (Optional)
Replacing the Staple Cartridge (For Optional Products)
Replacing the Staple Cartridge in the Stapler Unit (Finisher-AM1/Saddle Finisher-AM2)
Replacing the Staple Cartridge in the Saddle Stitcher Unit (Saddle Finisher-AM2)
Replacing the Staple Cartridge in the Stapler Unit (Staple Finisher-T1/Booklet Finisher-T1)
Replacing the Staple Case in the Saddle Stitcher Unit (Booklet Finisher-T1)
Removing Staple Waste (Finisher-AM1/Saddle Finisher-AM2)
Removing Punch Waste (Puncher Unit-BS1/Puncher Unit-BT1)
Removing Punch Waste (External 2/3 Hole Puncher-C1/External 2/4 Hole Puncher-C1/External 4 Hole Puncher-C1)
Operating the Limited Functions Mode
Replacing the Toner Cartridge
Replacing the Waste Toner Container
Routine Cleaning
Originals Cannot Be Scanned Properly (Cleaning the Platen Glass)
Originals Cannot Be Scanned Properly (Cleaning Method of the Original Scanning Area)
Scanned Originals Become Dirty (Manual Feeder Cleaning)
Scanned Originals Become Dirty (Automatic Feeder Cleaning)
Output Paper Becomes Dirty (Cleaning Inside of the Main Unit)
Output Paper Becomes Dirty (Wire Cleaning)
Output Paper Becomes Dirty (Roller Cleaning)
Output Paper Becomes Dirty (Belt Cleaning)
Streaks and Gloss Unevenness Appear on Output Paper (Refreshing the Fixing Belt)
Streaks and Gloss Unevenness Appear on Output Paper (Adjusting the Fixing Belt Auto Refresh Level)
Cleaning the Touch Panel Display
Consumables
Top » Maintenance » Loading Paper » Loading Transparencies/Clear Film
0L3X-0L7
You can load the transparencies/clear film to the following paper source.
Paper drawers of the main unit
Stack Bypass-B1
POD Deck Lite-B1
If the paper package has instructions about which side of the transparencies/clear film to load, follow those instructions.
When the transparency/clear film is loaded in the paper drawer of the main unit, the side facing down is the one printed on.
When the transparency/clear film is loaded in the Stack Bypass-B1, POD Deck Lite-B1, or Multi-drawer Paper Deck-B1, the side facing up is the one printed on.
You cannot load the transparencies/clear film into the Document Insertion Unit-M1.
When loading transparencies/clear film, make sure to hold only the edges of the sheets and avoid touching the print surface.
Do not load transparencies/clear film while the machine is printing. Doing so may cause a paper jam.
Use only transparencies/clear film intended for use with this machine. If you use other transparencies/clear film, you may cause damage to the machine.
It is recommended that output transparencies/clear film are immediately removed from the output tray to avoid folding of the transparencies/clear film and paper jams.
Return the remaining transparencies/clear film to their original package for storage, avoiding locations subject to high temperatures/clear film and humidity. Leaving transparencies/clear film loaded for an extended period of time may cause the sheets to stick together and result in a paper jam.
Leaving transparencies/clear film loaded for an extended period of time may cause the sheets to stick together and result in difficulties feeding the transparencies/clear film. In this case, fan the loaded transparencies/clear film well, reduce the number of sheets or use new transparencies/clear film.
When printing on transparencies/clear film, depending on the type of image, the image may become dense. When this happens, adjust the density for the output image.
If a paper jam occurs, fan the loaded transparencies/clear film well.
