e-ManualTopSite mapHelp
Category Top
Loading Paper
Loading Paper into a Paper Drawer
Adjusting a Paper Drawer to Hold a Different Paper Size
Loading Envelopes
Loading Pre-Punched Paper
Loading Transparencies/Clear Film
Loading Tab Paper
Loading Paper into the POD Deck Lite-B1 (Optional)
Loading Paper into the Multi-drawer Paper Deck-B1 (Optional)
Loading Paper into the Document Insertion Unit-M1 (Optional)
Replacing the Staple Cartridge (For Optional Products)
Replacing the Staple Cartridge in the Stapler Unit (Finisher-AM1/Saddle Finisher-AM2)
Replacing the Staple Cartridge in the Saddle Stitcher Unit (Saddle Finisher-AM2)
Replacing the Staple Cartridge in the Stapler Unit (Staple Finisher-T1/Booklet Finisher-T1)
Replacing the Staple Case in the Saddle Stitcher Unit (Booklet Finisher-T1)
Removing Staple Waste (Finisher-AM1/Saddle Finisher-AM2)
Removing Punch Waste (Puncher Unit-BS1/Puncher Unit-BT1)
Removing Punch Waste (External 2/3 Hole Puncher-C1/External 2/4 Hole Puncher-C1/External 4 Hole Puncher-C1)
Operating the Limited Functions Mode
Replacing the Toner Cartridge
Replacing the Waste Toner Container
Routine Cleaning
Originals Cannot Be Scanned Properly (Cleaning the Platen Glass)
Originals Cannot Be Scanned Properly (Cleaning Method of the Original Scanning Area)
Scanned Originals Become Dirty (Manual Feeder Cleaning)
Scanned Originals Become Dirty (Automatic Feeder Cleaning)
Output Paper Becomes Dirty (Cleaning Inside of the Main Unit)
Output Paper Becomes Dirty (Wire Cleaning)
Output Paper Becomes Dirty (Roller Cleaning)
Output Paper Becomes Dirty (Belt Cleaning)
Streaks and Gloss Unevenness Appear on Output Paper (Refreshing the Fixing Belt)
Streaks and Gloss Unevenness Appear on Output Paper (Adjusting the Fixing Belt Auto Refresh Level)
Cleaning the Touch Panel Display
Consumables
Top » Maintenance » Loading Paper » Loading Pre-Punched Paper
0L3X-0L6
You can load pre-punched paper to the following paper source:
Paper drawers of the main unit
Stack Bypass-B1
POD Deck Lite-B1
When loading pre-punched paper, take note of the orientation of the binding holes and the image.
When pre-punched paper is loaded in the paper drawer of the main unit, the side facing down is the one printed on.
When pre-punched paper is loaded in the Stack Bypass-B1, POD Deck Lite-B1, or Multi-drawer Paper Deck-B1, the side facing up is the one printed on.
If you are making one-sided prints, select [Face Up (Reverse Order)] in [Face Up/Face Down]. (See "Collating Copies.")
If you want to output prints with the printed face down, select plain paper with horizontal (landscape) orientation in [Select Paper]. (See "Paper Selection.")
