Operating the Limited Functions Mode
If a specific message (the service call message) appears on the display, operate the Limited Functions Mode.
If you set the Limited Functions Mode to 'On', the machine stops using the specific function that has a malfunction, and you may make copies/prints using other functions that can operate normally.
Call your service representative before you operate the module separation switch.
E590
Cause:
The Puncher Unit-BS1 or Puncher Unit-BT1 is out of order.
Remedy:
You can make copies/prints using functions other than the hole punch function by operating the Limited Functions Mode.
E514, E530, E531, E532, E535, E537, E539, E540, E542, E566, E567, E568, E577, E578, E57a, E57b, E57c, E585
Cause:
The Finisher-AM1 or Saddle Finisher-AM2 is out of order.
Remedy:
You can only output copies/prints by operating the Limited Functions Mode to restrict all of the functions for the finisher such as staple and collate.
E503-8004, E5a7, E5af, E5f0, E5f1, E5f2, E5f3, E5f4, E5f6, E5fa, E5fb, E5fc, E5fd, E5fe, E5ff
Cause:
The saddle stitcher unit of the Saddle Finisher-AM2 or the Booklet Trimmer-D1is out of order.
Remedy:
You can make copies/prints using functions other than the saddle stitch function by operating the Limited Functions Mode.
E518, E562, E569, E56a, E56b, E56e
Cause:
The Paper Folding Unit-F1 is out of order.
Remedy:
You can make copies/prints without using the folding mode by operating the Limited Functions Mode.
E5a1, E5a2, E5a3, E5a4 (excluding Detailed Code 85h), E5a5, E5a8, E5a9, E5aa (excluding Detailed Code 07h), E5ab, E5ac, E5ad, E5ae, E5b0 (excluding Detailed Code 13h), E5b2, E5b4, E5b5, E5b6, E5b8, E5b9, E5bd, E5c0, E5c1, E5c2, E5c3, E5c4, E5c5 (excluding Detailed Code 08h), E5c6, E5c7, E5d0, E5d1, E5d2 (excluding Detailed Code 05h), E5d4, E5d6 (excluding Detailed Code 06h), E5d7 (excluding Detailed Code 06h), E5d8, E5d9
Cause:
The Perfect Binder-D1 is out of order.
Remedy:
You can make copies/prints using functions other than the Perfect Binding mode by operating the Limited Functions Mode.
After setting the Limited Functions Mode to 'On', the corresponding function will be grayed out on the display, and cannot be used.
Press [Management Settings] → [Device Management] → [Limited Functions Mode].
If the Staple Finisher-T1/Booklet Finisher-T1 is attached, proceed to step 4.
For instructions on setting the Limited Functions Mode from the Service Call Message screen, see "Setting the Limited Functions Mode from the Service Call Message Screen."
Select the finishing mode you want to limit.
4.
Select [On] or [Off] → press [OK].
5.
Press [Close].
The Limited Functions Mode is enabled only after you restart the machine (the main power is turned OFF, and then back ON). For instructions on restarting (turning the main power OFF, and then back ON) the machine, see "Main Power and Energy Saver Key."
» Maintenance » Operating the Limited Functions Mode
0L3X-0LU
