Category Top
Overview of This Function
Advanced Box/Network Settings
Mail Box
Advanced Box
Network
Memory Media
Flow of Operations for Accessing Stored Files
Printing Files Stored in a Mail Box
Printing Files Stored in the Advanced Box
Printing Files Stored on the Network
Printing Files Stored in Memory Media
Canceling a Job While Printing
Reserving Jobs
Arranging Files Stored in a Mail Box
Checking File Information
Previewing a File
Operations for Files Stored in a Mail Box
Printing Lists
Arranging Files and Folders Stored in the Advanced Box
Checking Detailed Information of the Advanced Box
Personal Space Operations
Folder Operations
Previewing a File
Operations for Files Stored in a Folder
Arranging Files and Folders Stored on the Network
Checking Storage Information
Folder Operations
Previewing a File
File Operations
Arranging Files and Folders Stored in Memory Media
Checking the Detailed Information for Memory Media
Folder Operations
Previewing a File
File Operations
Printing a Sample
Storing Print Settings
Adjusting Density During Printing
Merging Files When Printing
Favorite Settings
Storing Favorite Settings
Recalling/Deleting Favorite Settings
Changing Color Modes
Paper Selection
Collating Prints
Two-Sided Printing
Convenient Modes for Printing
Adding a Cover
Inserting Sheets
Booklet Mode
Job Separator
Shifting the Original Image Using the Numeric Keys
Adding a Secure Watermark
Document Scan Lock
Document Scan Lock (TL Code)
Document Scan Lock (QR Code)
Superimpose Image
Gutter
Page Numbering
Copy Set Numbering
Watermark Printing
Date Printing
Adjusting the Color
Adjust One-Touch Color
Print on Tab
Adjusting the Print Resolution
Printing with Halftones
Adjusting Printing to Fit the Paper Size
Enlarging the Print Area
Printing Files with Multiple Pages on One Page (N On 1)
Printing Comments
Printing Password Protected PDF Files
Enlarging and Reducing Prints
Setting the Print Orientation
Setting the Print Position
Sending a File
Unavailable Combination of Functions
Top » Access Stored Files » Changing Color Modes
06RH-15X
This machine comes with the Automatic Color Selection mode, which recognizes whether an file is in color or black-and-white, and then automatically switches between the Full Color mode and Black mode. You can also manually switch between the Full Color, Black, Single Color, and Two Colors modes whenever necessary.
As an example, the procedure to select and print a file stored in a mail box is explained in this section.
Auto (Color/Black)
If the Auto (Color/Black) mode is selected, the machine automatically recognizes whether the file is in color or black-and-white. Color files are printed in the Color mode, while black-and-white files are printed in the Black mode.
Black
The Black mode always prints in black-and-white regardless of whether the file is in color or black-and-white.
Single Color
The Single Color mode enables you to make one-color prints.
*1 File
*2 Print
Two Colors
The Two Colors mode enables you to make two-color prints, composed of a color you specify, and black.
*1 File
*2 Print
You can select Red, Green, Blue, Yellow, Magenta, or Cyan as the color in the Single Color mode and the Two Colors mode.
Files comprised of black-and-white images stored in a mail box cannot be printed in the Two Color mode. Files comprised of color and black-and-white images stored in a mail box can be printed in the Two Color mode.
When printing CMYK files stored in mail boxes, only [Auto (Color/Black)] can be selected. (To print full color CMYK files, only [Auto (Color/Black)] can be specified. To print black CMYK files, [Black] can also be specified.)
The Single Color mode and Two Colors mode are available for printing file from a mail box.
If a file comprised of color and black-and-white images is stored in a mail box using [Store in Mail Box] of the Copy function or using Scan and Store function, and the file is printed in the Two Colors mode, black-and-white page is counted as a color print. If a file comprised of color and black-and-white images is stored in a mail box from a computer, and the file is printed in the Two Colors mode, black-and-white page is counted as a black-and-white print.
Press [Access Stored Files] → [Mail Box].
Select the desired Mail Box → select the desired file → press [Print].
Press [Select Color].
4.
Select [Auto (Color/Black)], [Black], [Single Color], or [Two Colors] → press [OK].
If [Advanced Box], [Network], or [Memory Media] is selected in step 1, you can select only [Auto (Color/Black)] or [Black].
You can also press [Change Print Settings], and then select the desired color mode from the color selection drop-down list on the Change Print Settings screen.
5.
Press [Start Printing].
If color printing is performed after black printing, a message may appear indicating the machine is preparing for color printing. Please wait for a moment until the message disappears. Color printing will start when the message disappears.
If you select [Sepia Tone] in the Adjust One-Touch Color mode, the color mode is automatically set to 'Single Color (Sepia Tone).'
The default setting is 'Auto (Color/Black).'
You can store the color mode in [Change Default Settings]. (See "Changing/Initializing the Default Settings for the Copy Function.")
