Category Top
Overview of This Function
Advanced Box/Network Settings
Mail Box
Advanced Box
Network
Memory Media
Flow of Operations for Accessing Stored Files
Printing Files Stored in a Mail Box
Printing Files Stored in the Advanced Box
Printing Files Stored on the Network
Printing Files Stored in Memory Media
Canceling a Job While Printing
Reserving Jobs
Arranging Files Stored in a Mail Box
Checking File Information
Previewing a File
Operations for Files Stored in a Mail Box
Printing Lists
Arranging Files and Folders Stored in the Advanced Box
Checking Detailed Information of the Advanced Box
Personal Space Operations
Folder Operations
Previewing a File
Operations for Files Stored in a Folder
Arranging Files and Folders Stored on the Network
Checking Storage Information
Folder Operations
Previewing a File
File Operations
Arranging Files and Folders Stored in Memory Media
Checking the Detailed Information for Memory Media
Folder Operations
Previewing a File
File Operations
Printing a Sample
Storing Print Settings
Adjusting Density During Printing
Merging Files When Printing
Favorite Settings
Storing Favorite Settings
Recalling/Deleting Favorite Settings
Changing Color Modes
Paper Selection
Collating Prints
Two-Sided Printing
Convenient Modes for Printing
Adding a Cover
Inserting Sheets
Booklet Mode
Job Separator
Shifting the Original Image Using the Numeric Keys
Adding a Secure Watermark
Document Scan Lock
Document Scan Lock (TL Code)
Document Scan Lock (QR Code)
Superimpose Image
Gutter
Page Numbering
Copy Set Numbering
Watermark Printing
Date Printing
Adjusting the Color
Adjust One-Touch Color
Print on Tab
Adjusting the Print Resolution
Printing with Halftones
Adjusting Printing to Fit the Paper Size
Enlarging the Print Area
Printing Files with Multiple Pages on One Page (N On 1)
Printing Comments
Printing Password Protected PDF Files
Enlarging and Reducing Prints
Setting the Print Orientation
Setting the Print Position
Sending a File
Unavailable Combination of Functions
Top » Access Stored Files » Unavailable Combination of Functions
06RH-178
The following tables show the unavailable combinations of settings when you want to set more than one function at a time.
Print Function for Files Stored in a Mail Box
Function
Functions that Cannot Be Used in Combination
Automatic Paper Selection
Automatic Paper Selection (Auto Orientation)*1, Multi-Purpose Tray*2, Rotate 90 Degrees: Collate, Rotate 90 Degrees: Group, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Booklet: Saddle Fold, Booklet: Booklet Scan, Booklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Print on Tab
Automatic Paper Selection*1, Multi-Purpose Tray*2, Rotate 90 Degrees: Collate, Rotate 90 Degrees: Group, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Booklet: Saddle Fold, Different Size Originals*3, Booklet: Booklet Scan, Booklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction
Paper Drawer Auto Selection
Multi-Purpose Tray
Automatic Paper Selection*2, Automatic Paper Selection (Auto Orientation)*2, Paper Drawer Auto Selection*2, Collate*4, Group*4, Rotate 90 Degrees: Collate*2, Rotate 90 Degrees: Group*2, Offset Collate*2, Offset Group*2, Staple*2, Saddle Stitch*2, Saddle Stitch: Add Cover (Print/Leave Blank)*2, Hole Punch*2, 2-Sided Printing*2, Document Separate Duplex Printing*2, Document Separate Continuous Printing*2, Sheet Insertion (Print/Leave Blank)*2, Chapter Page*2, Job Separator*2, Booklet: Booklet Scan*2, Booklet: Do Not Booklet Scan*2, Booklet: Saddle Stitch*2, Booklet: Add Cover*2, Booklet: Divided Booklet*2, Booklet: Creep Correction*2, Superimpose Image*4
Print Sample
Group, Rotate 90 Degrees: Group, Offset Group, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Multiple Documents
Collate
Multi-Purpose Tray*4, Group*1, Rotate 90 Degrees: Collate*1, Rotate 90 Degrees: Group*1, Offset Collate*1, Offset Group*1, Staple*1, Saddle Stitch*1, Saddle Stitch: Add Cover (Print/Leave Blank)*1, Booklet: Booklet Scan, Booklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction
Group
Multi-Purpose Tray*4, Print Sample, Collate*1, Rotate 90 Degrees: Collate*1, Rotate 90 Degrees: Group*1, Offset Collate*1, Offset Group*1, Staple*1, Saddle Stitch*1, Saddle Stitch: Add Cover (Print/Leave Blank)*1, Booklet: Saddle Fold, Document Separate Continuous Printing, Front Cover, Back Cover, Sheet Insertion (Print/Leave Blank), Chapter Page, Tab Paper, Job Separator, Booklet: Booklet Scan, Booklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Secure Watermark: Copy Set Numbering, Copy Set Numbering, Print on Tab
Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Multi-Purpose Tray*2, Collate*1, Group*1, Rotate 90 Degrees: Group*1, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Hole Punch, Booklet: Saddle Fold, Front Cover, Back Cover, Sheet Insertion (Print/Leave Blank), Chapter Page, Tab Paper, Job Separator, Booklet: Booklet Scan, Booklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction
Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Multi-Purpose Tray*2, Print Sample, Collate*1, Group*1, Rotate 90 Degrees: Collate*1, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Hole Punch, Booklet: Saddle Fold, Document Separate Continuous Printing, Front Cover, Back Cover, Sheet Insertion (Print/Leave Blank), Chapter Page, Tab Paper, Job Separator, Booklet: Booklet Scan, Booklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Secure Watermark: Copy Set Numbering, Copy Set Numbering, Print on Tab
Offset Collate
Multi-Purpose Tray*2, Collate*1, Group*1, Rotate 90 Degrees: Collate, Rotate 90 Degrees: Group, Offset Group*1, Staple*1, Saddle Stitch*1, Saddle Stitch: Add Cover (Print/Leave Blank)*1, Booklet: Booklet Scan, Booklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction
Offset Group
Multi-Purpose Tray*2, Print Sample, Collate*1, Group*1, Rotate 90 Degrees: Collate, Rotate 90 Degrees: Group, Offset Collate*1, Staple*1, Saddle Stitch*1, Saddle Stitch: Add Cover (Print/Leave Blank)*1, Booklet: Saddle Fold, Document Separate Continuous Printing, Front Cover, Back Cover, Sheet Insertion (Print/Leave Blank), Chapter Page, Tab Paper, Job Separator, Booklet: Booklet Scan, Booklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Secure Watermark: Copy Set Numbering, Copy Set Numbering, Print on Tab
Staple
Multi-Purpose Tray*2, Collate*1, Group*1, Rotate 90 Degrees: Collate, Rotate 90 Degrees: Group, Offset Collate*1, Offset Group*1, Saddle Stitch*1, Saddle Stitch: Add Cover (Print/Leave Blank)*1, Booklet: Saddle Fold, Booklet: Booklet Scan, Booklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Print on Tab*5
Saddle Stitch
Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Multi-Purpose Tray*2, Print Sample, Collate*1, Group*1, Rotate 90 Degrees: Collate, Rotate 90 Degrees: Group, Offset Collate*1, Offset Group*1, Staple*1, Saddle Stitch: Add Cover (Print/Leave Blank)*1, Hole Punch, Booklet: Saddle Fold, 1-Sided Printing, Different Size Originals*3, Front Cover, Back Cover, Sheet Insertion (Print/Leave Blank), Chapter Page, Tab Paper, Job Separator, Booklet: Booklet Scan, Booklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Secure Watermark: Copy Set Numbering, Superimpose Image, Page Numbering, Copy Set Numbering, Watermark, Print Date, Print on Tab
Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Multi-Purpose Tray*2, Print Sample, Collate*1, Group*1, Rotate 90 Degrees: Collate, Rotate 90 Degrees: Group, Offset Collate*1, Offset Group*1, Staple*1, Saddle Stitch*1, Hole Punch, Booklet: Saddle Fold, 1-Sided Printing, Different Size Originals*3, Front Cover, Back Cover, Sheet Insertion (Print/Leave Blank), Chapter Page, Tab Paper, Job Separator, Booklet: Booklet Scan, Booklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Secure Watermark: Copy Set Numbering, Superimpose Image, Page Numbering, Copy Set Numbering, Watermark, Print Date, Print on Tab
Hole Punch
1-Sided Printing
Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Booklet: Saddle Fold, 2-Sided Printing*1, Document Separate Duplex Printing*1, Document Separate Continuous Printing*1, Booklet: Booklet Scan, Booklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction
2-Sided Printing
Multi-Purpose Tray*2, 1-Sided Printing*1, Merge Files and Print, Booklet: Booklet Scan, Booklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Print on Tab
Multi-Purpose Tray*2, 1-Sided Printing*1, Document Separate Continuous Printing*1, Single Document, Multiple Documents, Booklet: Booklet Scan, Booklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Print on Tab
Multi-Purpose Tray*2, Group, Rotate 90 Degrees: Group, Offset Group, 1-Sided Printing*1, Document Separate Duplex Printing*1, Single Document, Multiple Documents, Booklet: Booklet Scan, Booklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Print on Tab
Front Cover
Group, Rotate 90 Degrees: Collate, Rotate 90 Degrees: Group, Offset Group, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Booklet: Saddle Fold, Single Document, Multiple Documents, Merge Files and Print, Tab Paper, Job Separator, Booklet: Booklet Scan, Booklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Superimpose Image, Print on Tab
Back Cover
Multi-Purpose Tray*2, Group, Rotate 90 Degrees: Collate, Rotate 90 Degrees: Group, Offset Group, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Booklet: Saddle Fold, Single Document, Multiple Documents, Merge Files and Print, Tab Paper, Job Separator, Booklet: Booklet Scan, Booklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Superimpose Image, Print on Tab
Chapter Page
Tab Paper
Group, Rotate 90 Degrees: Collate, Rotate 90 Degrees: Group, Offset Group, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Booklet: Saddle Fold, Single Document, Multiple Documents, Front Cover, Back Cover, Sheet Insertion (Print/Leave Blank), Chapter Page, Job Separator, Booklet: Booklet Scan, Booklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Superimpose Image, Print on Tab
Job Separator
Multi-Purpose Tray*2, Group, Rotate 90 Degrees: Collate, Rotate 90 Degrees: Group, Offset Group, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Booklet: Saddle Fold, Single Document, Multiple Documents, Front Cover, Back Cover, Sheet Insertion (Print/Leave Blank), Chapter Page, Tab Paper, Booklet: Booklet Scan, Booklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Superimpose Image, Print on Tab
Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Multi-Purpose Tray*2, Collate, Group, Rotate 90 Degrees: Collate, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Hole Punch, Booklet: Saddle Fold, 1-Sided Printing, 2-Sided Printing, Document Separate Duplex Printing, Document Separate Continuous Printing, Different Size Originals*3, Multiple Documents*6, Front Cover, Back Cover, Sheet Insertion (Print/Leave Blank), Chapter Page, Tab Paper, Job Separator, Booklet: Do Not Booklet Scan, Shift, Secure Watermark: Watermark, Secure Watermark: Date, Secure Watermark: Copy Set Numbering, Secure Watermark: Serial Number, Secure Watermark: ID/User Name, Document Scan Lock (Scan Lock Information), Document Scan Lock (Tracking Information), Superimpose Image, Gutter, Watermark, Print Date, Print on Tab
Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Multi-Purpose Tray*2, Collate, Group, Rotate 90 Degrees: Collate, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Hole Punch, Booklet: Saddle Fold, 1-Sided Printing, 2-Sided Printing, Document Separate Duplex Printing, Document Separate Continuous Printing, Different Size Originals*3, Multiple Documents*6, Front Cover, Back Cover, Sheet Insertion (Print/Leave Blank), Chapter Page, Tab Paper, Job Separator, Booklet: Booklet Scan, Booklet: Divided Booklet, Booklet: Creep Correction, Shift, Secure Watermark: Watermark, Secure Watermark: Date, Secure Watermark: Copy Set Numbering, Secure Watermark: Serial Number, Secure Watermark: ID/User Name, Document Scan Lock (Scan Lock Information), Document Scan Lock (Tracking Information), Superimpose Image, Gutter, Page Numbering, Copy Set Numbering, Watermark, Print Date, Print on Tab
Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Multi-Purpose Tray*2, Collate, Group, Rotate 90 Degrees: Collate, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Hole Punch, Booklet: Saddle Fold, 1-Sided Printing, 2-Sided Printing, Document Separate Duplex Printing, Document Separate Continuous Printing, Different Size Originals*3, Multiple Documents*6, Front Cover, Back Cover, Sheet Insertion (Print/Leave Blank), Chapter Page, Tab Paper, Job Separator, Shift, Secure Watermark: Watermark, Secure Watermark: Date, Secure Watermark: Copy Set Numbering, Secure Watermark: Serial Number, Secure Watermark: ID/User Name, Document Scan Lock (Scan Lock Information), Document Scan Lock (Tracking Information), Superimpose Image, Gutter, Watermark, Print Date, Print on Tab
Booklet: Add Cover
Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Multi-Purpose Tray*2, Collate, Group, Rotate 90 Degrees: Collate, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Hole Punch, Booklet: Saddle Fold, 1-Sided Printing, 2-Sided Printing, Document Separate Duplex Printing, Document Separate Continuous Printing, Different Size Originals*3, Multiple Documents*6, Front Cover, Back Cover, Sheet Insertion (Print/Leave Blank), Chapter Page, Tab Paper, Job Separator, Booklet: Do Not Booklet Scan, Booklet: Creep Correction*7, Shift, Secure Watermark: Watermark, Secure Watermark: Date, Secure Watermark: Copy Set Numbering, Secure Watermark: Serial Number, Secure Watermark: ID/User Name, Document Scan Lock (Scan Lock Information), Document Scan Lock (Tracking Information), Superimpose Image, Gutter, Watermark, Print Date, Print on Tab
Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Multi-Purpose Tray*2, Collate, Group, Rotate 90 Degrees: Collate, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Hole Punch, Booklet: Saddle Fold, 1-Sided Printing, 2-Sided Printing, Document Separate Duplex Printing, Document Separate Continuous Printing, Different Size Originals*3, Multiple Documents*6, Front Cover, Back Cover, Sheet Insertion (Print/Leave Blank), Chapter Page, Tab Paper, Job Separator, Booklet: Do Not Booklet Scan, Booklet: Divided Booklet*7, Shift, Secure Watermark: Watermark, Secure Watermark: Date, Secure Watermark: Copy Set Numbering, Secure Watermark: Serial Number, Secure Watermark: ID/User Name, Document Scan Lock (Scan Lock Information), Document Scan Lock (Tracking Information), Superimpose Image, Gutter, Watermark, Print Date, Print on Tab
Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Group, Rotate 90 Degrees: Collate, Rotate 90 Degrees: Group, Offset Group, Staple, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Hole Punch, 1-Sided Printing, Front Cover, Back Cover, Sheet Insertion (Print/Leave Blank), Chapter Page, Tab Paper, Job Separator, Booklet: Booklet Scan, Booklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Secure Watermark: Copy Set Numbering, Superimpose Image, Page Numbering, Copy Set Numbering, Watermark, Print Date, Print on Tab
Automatic Paper Selection (Auto Orientation), Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Booklet: Booklet Scan, Booklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction
Single Document
Document Separate Duplex Printing, Document Separate Continuous Printing, Multiple Documents, Merge Files and Print, Front Cover, Back Cover, Sheet Insertion (Print/Leave Blank), Chapter Page, Tab Paper, Job Separator
Multiple Documents
Print Sample, Document Separate Duplex Printing, Document Separate Continuous Printing, Single Document, Merge Files and Print, Front Cover, Back Cover, Sheet Insertion (Print/Leave Blank), Chapter Page, Tab Paper, Job Separator, Booklet: Booklet Scan*6, Booklet: Do Not Booklet Scan*6, Booklet: Saddle Stitch*6, Booklet: Add Cover*6, Booklet: Divided Booklet*6, Booklet: Creep Correction*6
2-Sided Printing, Single Document, Multiple Documents, Front Cover, Back Cover, Sheet Insertion (Print/Leave Blank), Chapter Page
Page Numbering
Two Colors*8, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Booklet: Saddle Fold, Booklet: Do Not Booklet Scan, Copy Set Numbering*9, Watermark*9, Print Date*9, Shift, Document Scan Lock (Scan Lock Information), Document Scan Lock (Tracking Information), Superimpose Image, Print on Tab
Copy Set Numbering
Two Colors*8, Group, Rotate 90 Degrees: Group, Offset Group, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Booklet: Saddle Fold, Booklet: Do Not Booklet Scan, Page Numbering*9, Watermark*9, Print Date*9, Shift, Secure Watermark: Watermark, Secure Watermark: Date, Secure Watermark: Copy Set Numbering, Secure Watermark: Serial Number, Secure Watermark: ID/User Name, Document Scan Lock (Scan Lock Information), Document Scan Lock (Tracking Information), Superimpose Image, Print on Tab
Watermark
Two Colors*10, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Booklet: Saddle Fold, Booklet: Booklet Scan, Booklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Page Numbering*9, Copy Set Numbering*9, Print Date*9, Shift, Secure Watermark: Watermark, Secure Watermark: Date, Secure Watermark: Copy Set Numbering, Secure Watermark: Serial Number, Secure Watermark: ID/User Name, Document Scan Lock (Scan Lock Information), Document Scan Lock (Tracking Information), Superimpose Image, Print Date, Print on Tab
Print Date
Two Colors*10, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Booklet: Saddle Fold, Booklet: Booklet Scan, Booklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Page Numbering*9, Copy Set Numbering*9, Watermark*9, Shift, Secure Watermark: Watermark, Secure Watermark: Date, Secure Watermark: Copy Set Numbering, Secure Watermark: Serial Number, Secure Watermark: ID/User Name, Document Scan Lock (Scan Lock Information), Document Scan Lock (Tracking Information), Superimpose Image, Watermark, Print on Tab
Superimpose Image
Two Colors*10, Multi-Purpose Tray*4, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Booklet: Saddle Fold, Front Cover, Back Cover, Sheet Insertion (Print/Leave Blank), Chapter Page, Tab Paper, Job Separator, Booklet: Booklet Scan, Booklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Secure Watermark: Watermark, Secure Watermark: Date, Secure Watermark: Copy Set Numbering, Secure Watermark: Serial Number, Secure Watermark: ID/User Name, Document Scan Lock (Scan Lock Information), Document Scan Lock (Tracking Information), Page Numbering, Copy Set Numbering, Watermark, Print Date
Gutter
Shift
Booklet: Booklet Scan, Booklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Secure Watermark: Copy Set Numbering, Page Numbering, Copy Set Numbering, Watermark, Print Date, Print on Tab
Print on Tab
Automatic Paper Selection, Group, Rotate 90 Degrees: Group, Offset Group, Staple*5, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Booklet: Saddle Fold, 2-Sided Printing, Document Separate Duplex Printing, Document Separate Continuous Printing, Front Cover, Back Cover, Sheet Insertion (Print/Leave Blank), Chapter Page, Tab Paper, Job Separator, Booklet: Booklet Scan, Booklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Page Numbering, Copy Set Numbering, Watermark, Print Date, Shift, Gutter
Single Color, Two Colors*8, Booklet: Booklet Scan, Booklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Secure Watermark: Date*1, Secure Watermark: Copy Set Numbering*1, Secure Watermark: Serial Number*1, Secure Watermark: ID/User Name*1, Document Scan Lock (Scan Lock Information)*11, Document Scan Lock (Tracking Information), Superimpose Image, Copy Set Numbering, Watermark, Print Date, Color Balance
Single Color, Two Colors*8, Booklet: Booklet Scan, Booklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Secure Watermark: Watermark*1, Secure Watermark: Copy Set Numbering*1, Secure Watermark: Serial Number*1, Secure Watermark: ID/User Name*1, Document Scan Lock (Scan Lock Information)*11, Document Scan Lock (Tracking Information), Superimpose Image, Copy Set Numbering, Watermark, Print Date, Color Balance,
Single Color, Two Colors*8, Group, Rotate 90 Degrees: Group, Offset Group, Saddle Stitch, Saddle Stitch: Add Cover (Print/Leave Blank), Booklet: Saddle Fold, Booklet: Booklet Scan, Booklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Shift, Secure Watermark: Watermark*1, Secure Watermark: Date*1, Secure Watermark: Serial Number*1, Secure Watermark: ID/User Name*1, Document Scan Lock (Scan Lock Information)*11, Document Scan Lock (Tracking Information), Superimpose Image, Copy Set Numbering, Watermark, Print Date, Color Balance
Single Color, Two Colors*8, Booklet: Booklet Scan, Booklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Secure Watermark: Watermark*1, Secure Watermark: Date*1, Secure Watermark: Copy Set Numbering*1, Secure Watermark: ID/User Name*1, Document Scan Lock (Scan Lock Information)*11, Document Scan Lock (Tracking Information), Superimpose Image, Copy Set Numbering, Watermark, Print Date, Color Balance
Single Color, Two Colors*8, Booklet: Booklet Scan, Booklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Secure Watermark: Watermark*1, Secure Watermark: Date*1, Secure Watermark: Copy Set Numbering*1, Secure Watermark: Serial Number*1, Document Scan Lock (Scan Lock Information)*11, Document Scan Lock (Tracking Information), Superimpose Image, Copy Set Numbering, Watermark, Print Date, Color Balance
Single Color, Two Colors*10, Booklet: Booklet Scan, Booklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Secure Watermark: Watermark*11, Secure Watermark: Date*11, Secure Watermark: Copy Set Numbering*11, Secure Watermark: Serial Number*11, Secure Watermark: ID/User Name*11, Superimpose Image, Page Numbering, Copy Set Numbering, Watermark, Print Date, Color Balance
Single Color, Two Colors*10, Booklet: Booklet Scan, Booklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Secure Watermark: Watermark, Secure Watermark: Date, Secure Watermark: Copy Set Numbering, Secure Watermark: Serial Number, Secure Watermark: ID/User Name, Superimpose Image, Page Numbering, Copy Set Numbering, Watermark, Print Date, Color Balance
Color Balance
Adjust One-Touch Color (Sepia)
Black, Auto (Color/Black)
Single Color
Two Colors*1, Black*1, Auto (Color/Black)*1, Secure Watermark: Watermark, Secure Watermark: Date, Secure Watermark: Copy Set Numbering, Secure Watermark: Serial Number, Secure Watermark: ID/User Name, Document Scan Lock (Scan Lock Information), Document Scan Lock (Tracking Information)
Two Colors
Single Color*1, Black*1, Auto (Color/Black)*1, Secure Watermark: Watermark*8, Secure Watermark: Date*8, Secure Watermark: Copy Set Numbering*8, Secure Watermark: Serial Number*8, Secure Watermark: ID/User Name*8, Document Scan Lock (Scan Lock Information)*10, Document Scan Lock (Tracking Information)*10, Superimpose Image*10, Page Numbering*8, Copy Set Numbering*8, Watermark*10, Print Date*10
Black
Single Color*1, Two Colors*1, Auto (Color/Black)*1, Adjust One-Touch Color (Sepia)
Auto (Color/Black)
Single Color*1, Two Colors*1, Black*1, Adjust One-Touch Color (Sepia)
*1 If you select these modes in combination, the mode which is set last has priority.
*2 Combination unavailable if [Custom Size] or [Envelope] is selected.
*3 Output prints scanned using the Different Size Originals mode.
*4 Combination unavailable if [Envelope] is selected.
*5 You cannot specify the Staple for Top Right Corner, Bottom Right Corner, or Right Double stapling with tab paper.
*6 Combination unavailable if the record sizes of the selected files are different.
*7 Combination unavailable if [Auto] is selected for the Creep Correction mode.
*8 If you select these modes in combination, the text set in these modes is printed in black regardless of the specified color of the text.
*9 You can combine three modes at most among the following four modes: Page Numbering, Copy Set Numbering, Watermark, and Print Date.
*10 If you are using a file which is stored with Two Colors setting from the printer driver, the text set in these modes is printed in black regardless of the specified color of the text. Combination unavailable for other settings.
*11 You cannot combine these modes if Document Scan Lock Information (TL Code) is selected. You can combine these modes if Document Scan Lock Information (QR Code) is selected.
Print Function for PDF/XPS Files
Function
Booklet, N on 1, Match Paper Size
Standard Size Paper Selection
Booklet*1, Rotate 90 Degrees
Collate (Page Order)
Booklet, Group (Same Pages)*3, Staple*3
Group (Same Pages)
Forced Secure Watermark*2, Booklet, Collate (Page Order)*3, Staple*3
Hole Punch
Booklet, Rotate 90 Degrees
Staple
Booklet, Offset Collate, Collate (Page Order)*3, Group (Same Pages)*3, Rotate 90 Degrees
Rotate 90 Degrees
Booklet, Standard Size Paper Selection, Hole Punch, Offset Collate, Staple
Offset Collate
Booklet, Staple, Rotate 90 Degrees
2-Sided Printing
Booklet
Match Paper Size
N on 1
Booklet
Forced Document Scan Lock (QR Code), Forced Document Scan Lock (TL Code), Forced Secure Watermark, 2-Sided Printing, Offset Collate, Rotate 90 Degrees, Staple, Hole Punch, Group (Same Pages), Collate (Page Order), Standard Size Paper Selection*1, Automatic Paper Selection
Forced Document Scan Lock (TL Code), Booklet, Group (Same Pages)*2
Forced Document Scan Lock (QR Code), Forced Secure Watermark, Booklet
Encrypted PDF
PDF Files with a Security Policy*4
Encrypted PDF*4
*1 Combination unavailable if [Envelope] is selected.
*2 You cannot combine these modes when Copy Set Numbering is set for Secure Watermark.
*3 If you select these modes in combination, the mode which is set last has priority.
*4 You cannot set the same password for both Encrypted PDF and PDF Files with a Security Policy.
