06RH-15S
You can register up to nine frequently used setting combinations. You can also set easy to remember names for each.
This feature is useful for storing frequently used print settings.
As an example, the procedure for printing files that are stored in a Mail Box is explained in this section.
The settings stored in [Favorite Settings] are not deleted, even if the main power is turned OFF.
You can also store/edit favorite settings by pressing  → [Register/Edit Favorite Settings].
