Operations for Files Stored in a Folder
You can add/delete files in a folder.
Press [Access Stored Files] → [Advanced Box].
Select the desired storage space → select the directory where the file you want to print is stored.
Select the desired file → press [Edit File].
4.
Press [Delete].
5.
Press [Yes].
Changing a File Name (Change File Name)
Select the desired storage space → select the directory where the file you want to change the file name is stored.
4.
Press [Change File Name].
If you select multiple files and press [Change File Name], the selected (highlighted) file becomes the file whose title is changed.
5.
Enter a file name → press [OK].
Adding a File (Scan and Store)
You can scan an original and store it as a file.
Place your originals.
Select the desired storage space → select the desired folder level → press [Edit File].
4.
Press [Add Files (Scan and Store)].
5.
Specify the desired scan settings.
6.
Press
(Start).
If the following screen is displayed, after the last batch of originals is scanned, press [Start Storing].
If you place your original on the platen glass, press
(Start) to scan each original.
