Category Top
Overview of This Function
Advanced Box/Network Settings
Mail Box
Advanced Box
Network
Memory Media
Flow of Operations for Accessing Stored Files
Printing Files Stored in a Mail Box
Printing Files Stored in the Advanced Box
Printing Files Stored on the Network
Printing Files Stored in Memory Media
Canceling a Job While Printing
Reserving Jobs
Arranging Files Stored in a Mail Box
Checking File Information
Previewing a File
Operations for Files Stored in a Mail Box
Printing Lists
Arranging Files and Folders Stored in the Advanced Box
Checking Detailed Information of the Advanced Box
Personal Space Operations
Folder Operations
Previewing a File
Operations for Files Stored in a Folder
Arranging Files and Folders Stored on the Network
Checking Storage Information
Folder Operations
Previewing a File
File Operations
Arranging Files and Folders Stored in Memory Media
Checking the Detailed Information for Memory Media
Folder Operations
Previewing a File
File Operations
Printing a Sample
Storing Print Settings
Adjusting Density During Printing
Merging Files When Printing
Favorite Settings
Storing Favorite Settings
Recalling/Deleting Favorite Settings
Changing Color Modes
Paper Selection
Collating Prints
Two-Sided Printing
Convenient Modes for Printing
Adding a Cover
Inserting Sheets
Booklet Mode
Job Separator
Shifting the Original Image Using the Numeric Keys
Adding a Secure Watermark
Document Scan Lock
Document Scan Lock (TL Code)
Document Scan Lock (QR Code)
Superimpose Image
Gutter
Page Numbering
Copy Set Numbering
Watermark Printing
Date Printing
Adjusting the Color
Adjust One-Touch Color
Print on Tab
Adjusting the Print Resolution
Printing with Halftones
Adjusting Printing to Fit the Paper Size
Enlarging the Print Area
Printing Files with Multiple Pages on One Page (N On 1)
Printing Comments
Printing Password Protected PDF Files
Enlarging and Reducing Prints
Setting the Print Orientation
Setting the Print Position
Sending a File
Unavailable Combination of Functions
Top » Access Stored Files » Booklet Mode
Booklet Mode
06RH-165
This mode enables you to print documents in such a way that the prints are made into a booklet.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
For information on the Booklet Scan mode, see "Booklet Scanning."
Booklet
This mode enables you to print one-sided or two-sided files in such a way that the prints are made into a booklet.
When the Booklet Finisher-J1 is attached
Divided Booklet
This mode enables you to make a large document with many pages into a divided booklet.
Creep (Displacement) Correction
This mode enables you to adjust the position of the images in a booklet by calculating the width of the displacement between the outermost page and center page of the booklet
*1 Trimmed
*2 After the pages are trimmed, the outer margins of all pages are equal.
*3 The inner margins are set so that the inner margins of the outermost pages are wider than the inner margins of the center pages. The placement of the images on each page is adjusted by calculating the amount of displacement between the outermost page and innermost page of the booklet.
As an example, the procedure for printing files that are stored in a Mail Box is explained in this section.
This mode can be used only for printing a file stored in a mail box or a PDF or XPS file.
The Saddle Stitch and Divided Booklet modes can be set only if the Booklet Finisher-J1 is attached.
Be sure to correctly set the paper type. When printing on special types of paper, such as heavy paper, be sure to correctly set the paper type, especially if you are using heavy paper. If the type of paper is not set correctly, it could adversely affect the quality of the image. Moreover, the fixing unit may become dirty and require a service repair, or the paper could jam.
[Booklet Scan] can only be specified for the following paper sizes: LTR, LTRR, STMT, or STMTR.
The Booklet mode cannot be set if multiple files are selected, and their record sizes are different.
Press [Access Stored Files] → [Mail Box].
Select the desired Mail Box → select the desired file → press [Print].
Press [Change Print Settings].
4.
Press [Options] → [Booklet].
5.
Specify the booklet print settings.
Mail Box
Advanced Box/Network/Memory Media
Folding and Saddle Stitching:
Adding Covers:
Changing the Layout Size of a Booklet:
Press [Fold + Saddle Stitch].
If you do not want to saddle stitch, select [Fold Only].
If you do not want to set the Fold and Saddle Stitch modes, select [Do Not Fold].
Fold can be used only for printing a file stored in a mail box.
The maximum number of sheets that can be saddle stitched at one time is 16. If you want to saddle stitch 17 or more sheets, set the Divided Booklet mode.
If the number of sheets is 17 or more, the booklet is not saddle stitched.
Adding Covers:
Press [Add Cover] → [Print].
Press [Leave Blank] if you do not want to print on the cover.
If you selected [Booklet Scan], you can set <Front Cover>, <Front Inside Cover>, <Back Inside Cover>, and <Back Cover> individually.
To set the paper for the cover, press [Change] → select the paper source → press [OK].
If you want to select the multi-purpose tray when a paper size/type is already selected for the current or reserved job, press [Change MP Tray Paper].
You must select the same paper size for the cover page as that used for the main document.
If you are using Heavy paper, you can only print on <Front Inside Cover> or <Back Inside Cover>.
Only 14 lb bond to 80 lb cover (52 to 220 g/m2) paper can be used for the main document.
14 lb bond to 140 lb index (52 to 256 g/m2) paper can be used for the cover page.
[Add Cover] can be used only for printing a file stored in a mail box.
Press [Change] for <Layout Size>.
Select the desired booklet size → press [OK].
Only 12" x 18", 11" x 17", LGL, or LTRR paper can be used.
6.
Press [Set Details] → specify the detailed Booklet settings.
If you do not want to specify the detailed settings, proceed to step 7.
Making a divided booklet:
Setting the creep correction:
Adjusting the saddle stitch position:
Adjusting the fold position:
[Set Details] can be used only for printing a file stored in a mail box.
Press [Divided Booklet]  → set the number of sheets to divide → press [OK].
The maximum number of sheets, including cover sheets, that can be saddle stitched is:
29 lb bond to 55 lb cover (106 to 150 g/m2): 5 sheets
56 lb cover to 110 lb index (151 to 209 g/m2): 4 sheets
80 lb cover to 80 lb cover (210 to 220 g/m2): 2 sheets
The number of saddle stitched booklets that the booklet tray can hold depends on the number of sheets that each booklet contains.
1 to 5 sheets: 25 sets
6 to 10 sheets: 15 sets
11 to 16 sheets: 10 sets
Press [Creep Correction] → select the correction method → press [OK] → [OK].
If you select [Manual], press or to adjust the correction width.
Press [Change Fold/Stitch Pos.] → select the paper size for finishing.
Adjust the saddle stitch position using [-] or [+]→ press [OK] → [OK].
You can set [Change Fold/Stitch Pos.] only if you select [Fold + Saddle Stitch].
If you want to adjust the folding position, press [Adjust Fold Position] → adjust the folding position → press [OK].
You can set [Adjust Fold Position] only if you select [Fold Only].
7.
Press [OK] → [Close].
8.
Set the Booklet Tray guide to match the paper size.
11" x 17"/LGL
LTRR
Make sure to set the Booklet Tray guide to match the paper size. Setting the Booklet Tray guide incorrectly may result in a paper jam.
Saddle stitching is not performed if there is only one output sheet.
The accuracy of folds may vary, depending on the type and quantity of paper.
